LT1 fuel line questions
Old Jun 23, 2010 | 01:25 PM
mavrick331's Avatar
mavrick331
Default LT1 fuel line questions
Hi all,
I have a couple of questions, I'm building a Jeep YJ with a 96 LT1 out of a vette. First question, Is there a kit that will move the fuel lines to exit to the drivers side ? Can I use rubber fuel lines?. Second question (ok 3rd) The donor car had the fuel filter near the engine, the stock jeep is closer to the tank, does it matter where I put it?
Here is the Jeep build link:
http://www.jeepforum.com/forum/f12/m...-build-849557/
One more, What the heck is this and where on the LT1 does it go, can't see it in the 100 pics I took while I was tearing it apart.
Thanks Rick
Old Jun 23, 2010 | 01:48 PM
jnealg's Avatar
jnealg
I posted over there for you about the fuel line.
I'd rethink the LT1 in a YJ unless it was street only. Are you not concerned about the Opti getting wet?
Old Jun 23, 2010 | 07:04 PM
mavrick331's Avatar
mavrick331
Many Jeeps have LT1's. not worried...
I think the bracket I pictured is a plug wire holder, I installed the plug wires just a few moments ago and can't see were it would have gone, or is really needed. I did restore it as the picture shows.
Who will give me $100 bucks for it !!
Rick
Old Jun 23, 2010 | 08:23 PM
rodj's Avatar
rodj
Check out the rails from other LT1's
The intake I have has drv side exit and IIRC that came off a Impala or Caprice
See eBay item # 180446330235
These adapters allow you to connect -6 AN fittings with either rubber (AN barb fittings ) or s/s braided line to the stock LTX rails
http://www.summitracing.com/parts/RUS-641300/
Old Jun 24, 2010 | 09:26 AM
jnealg's Avatar
jnealg
Really? I didnt know that. makes me feel better about the doom and gloom about the opti!
Your project sounds like its going to be a lot of fun!
Seems like a lot of folks on here (CF) have Jeeps.
Rick
To LT1 fuel line questions
