Starting problem after trans replacement
Looks like the Starter Enable Relay is behind that panel.
I don't see any connector with wires like that in the manual. May be someone will respond.
The manual has a chart telling you what voltagesshould be at the Starter Enable Relay.
Have you gained access to the Starter Enable Relay?
There's a chart at 6D-3, but no starter enable relay...
Looking for the Multi Use Center disassembly section now...I'll find it, eventually...
I'll try for the DIC panel next...
Reading 8A 30-4...I've already done up to 3...I don't know where Ignition Switch connector C2, Terminal S is...
...But it's probably...behind the multi-use center...
Why did you remove the driver seat and the plastic panel under the
ECU
The ECU is under the passenger side of the dash.
Do the test measurements at the Starter Enable relay.
I pulled the kick panel off the pass side to see what the light connector looked like...It's a pink wire with a wht stripe, and an all wht wire in a stacked connector...the same as my loose connector on the drivers side. My 86 never had a drivers side kick panel (I suppose it's on a shelf in the PO's garage) so I never missed the light.
One mystery solved.
The relays behind that telltale panel are next.
Thanks for the pic!
First thing I checked was the two fuses...Top one is 15 amp labeled "Theft", bottom is 5 amp labeled "Cinj"...Both show continuity...
I visually checked what I think is the starter enable relay (the one in the middle that I labeled "2"...the one I labeled "1" should be the horn relay per the manual, and "3" should be the "audio alarm module"???)...
Step 3 says to check ignition switch connector C2, terminal S...I have no idea where those are...so I'll skip to -
Step 4 says to remove starter enable relay and connect a voltmeter from terminal E of connector and ground...and turn ignition switch to START w/clutch pedal depressed...(I assume this requires battery hooked up again)...So, I pull the relay out...
Removing the relay presents a sickening sight...brown slimey crap on all the connectors, on both the relay itself and the harness connector...
I'm guessing this is a burned out relay...No other connector has this crap on the terminals...
Before I try connecting the battery & voltmeter, I'm going to clean that harness connector...CRC makes a "QD Electronic Cleaner" in a spray can; I stuck a rag around the connector and sprayed away...Cleaned it up very nicely...
Seeing your picture of the relay connector it must have come from the factory like that.
With the relay removed, you should measure 12 volts to ground on the Yellow wire on Pin E and also Pin C when the ignition switch is in the Start position.
With the relay installed, every time you turn the ignition key to Start, you should hear the Starter Enable relay click.
That would indicate the relay is enabled and the Vats Decoder Module is grounding the Dark Green wire.
If that happens you should measure 12 volts coming out of the Relay on the Dark Green/White wire which goes to the Clutch Safety switch and after that switch turns into the Purple wire at the Starter Solenoid.
Bubba must have been a brave guy to go through all the trouble
and remove the DIC to put the goo in the plug.
Jumping E to A bypasses the relay.
You all ready know it's not the Clutch Safety switch so why don't you
install the relay and see if it clicks?
Maybe cleaning the goo out solved the problem.
If the Relay doesn't engage check the Dark Green wire for a ground signal.
You don't need to install the exhaust for the starter to work.
BTW: One of our members has a site describing bypassing the VATS module/relay/switch -
http://www.joestradingpost.com/vats/
This was Item # 5 of the manual's diagnostics...
...If engine cranks, go to Item # 6
Item # 6 is to remove the jumper, reconnect relay, and ground the DK GRN wire at pin B of the Starter Enable Relay, and turn ign switch to Start...
I don't see how I can ground the wire with the relay installed...
You could also pop the cover off the relay and jumper pin B to ground.
Back when I jumpered the A to E contacts in the Starter Enable Relay harness connector, the engine cranked & started, but there was/is no sound from the fuel pump, and the engine died after 4 - 5 secs...
I'm pretty much out of options now...I don't have the special diagnostic tools for the rest of the tests described in the manual...
Having it flat towed to a dealer (or Corvette specialist) looks like my last resort...
As you may have noticed, I'm pretty much bummed out by all this...I used to enjoy working on cars; but now, when I look at this car, I'm just really depressed...
When you first turn the ignition switch to On, the ECM will enable the fuel pump for about 2 seconds. It will shut the pump off If there are no reference pulses from the distributor indicating the engine is not be cranked or running.
That's normal. Obviously there must be some fuel pressure in the fuel rail or the engine wouldn't have run for the few seconds it did.
Also if you cycle the ignition switch On and Off a couple of times and not wait a couple of seconds, sometimes the ECM does not enable the fuel pump.
Your no crank problem points to the Pass Key Decoder circuit.
Either the key pellet is not being read properly because of bad contacts in the ignition key lock assembly, worn key pellet or the Pass Key Decoder Module is bad. (Not likely). If you're using a bypass resistor, it may be out of tolerance.
1) Are you sure when you turn the ignition key On, the Security light bulb comes on for a second then goes out?
2) What happens when you have either door open. Does the Security light flash on and off?
3) What happens with the passenger side door closed and the driver side door open and you lock the doors with the power door lock switch.
Does the Security light stay on solid?
Unlock the doors using the power door lock switch.
Does the Security light start blinking?
Drivers power door lock switch seems awfully loose...Like the plastic thingy isn't captive like it should be...but it still works...
My apologies about the Security light...I've been doing all my testing/bypassing with the drivers door open...
