technical gear question
Old Mar 21, 2002 | 11:45 PM
james holley's Avatar
james holley
Default technical gear question
my car has 2.59 gears and 255/50 tires. if i switched to 245/45 tires, in theory, what would the gear ratio be? (understand what im asking?) thanks.
Old Mar 22, 2002 | 01:04 AM
hotrod datson's Avatar
hotrod datson
Default Re: technical gear question (james holley)
most trans drives are 1:1 with out over drive.
I think in the 6 speed 4th gear is 1:1
with a 1/2" smaller tire Dia. it should be as if you went to a 2.54 rear gear
maybe this will help
RPM= MPH X gear ratio X Trans drive ratio X 336 divided by tire Diameter
gear ratio = RPM X tire Dia. / trans ratio / MPH / 336
MPH = RPM X tire Dia. / trans ratio / gear ratio / 336
and so on
Old Mar 22, 2002 | 01:19 AM
chaos on wheels's Avatar
chaos on wheels
Here's a fun program that will let you play with various tire sizes, gear ratios, etc.
http://www.vettextc.net/gear_program.htm
Old Mar 22, 2002 | 01:20 AM
VMAX451's Avatar
VMAX451
I think I see what you're asking, so I'll give it a shot...
You're using 16" wheels, correct? If so, switching from 255/50 tires to 245/45 tires would be the same as running the the original 255/50's with a 2.73 axle, not all that much of a difference.
Old Mar 22, 2002 | 12:27 PM
hotrod datson
Sorry for the mistake
i got in to a hurry, (wife nagging me to turn out the lights)
1/2" smaller tire would be like a 2.64
1" smaller tire would be like a 2.70
To technical gear question
