94 ecm swap, fbody into vette?
Old Jun 24, 2010 | 08:33 PM
2bar-c4's Avatar
2bar-c4
Default 94 ecm swap, fbody into vette?
Hello,
I was working on tuning my VE tables tonight and froze up the vett. ecm.I am not sure what happened, everything was going great and the laptop locked up. I do have a stock F body unit that I installed, it runs the motor but tunercat will not comunicate with this now. It gives me an "invalid response" message. Is this doable of am I going to have to send the vette unit to TC for repair before I can drive this thing?
Ron
Old Jun 25, 2010 | 10:40 PM
VenkmanP's Avatar
VenkmanP
You need to reprogram it with your Y code.
To do that, you either need to program it on the bench, or unplug the CCM. The latter is not really feasible unless you already have your dash apart...
Info for making a bench cable here:
http://www.akmcables.com/techinfo.htm
I think a few places sell premade bench cables.
Or if you know somebody with a 94-97 F body, you could put the PCM in their car and upload the Y bin.
Or you can just send the F PCM to a tuner and have them load your BIN.
Old Jun 28, 2010 | 12:36 PM
2bar-c4's Avatar
2bar-c4
Thanks for the reply Vis Croceus,
If anyone ever has this problem in the future pull both of the CCM fuses and then reflash with the Y code. so far so good.
Ron
Old Jun 30, 2010 | 12:33 AM
VenkmanP's Avatar
VenkmanP
That's good to know! I never thought to look for a CCM fuse...
To 94 ecm swap, fbody into vette?
