Left window SLOOWW...Right Window Fast??
Good luck with it.
Electrical motors wear out like anything else.
But they also work off of Voltage......So you could be experiencing loss of power due to corrosion resulting in weak connections. If you can find out how many volts are supposed to power that motor, then you could check with a meter and your question would be answered.
Weak Voltage=check the connections
Full Voltage= motor may be weak
I'd hate to tell you to buy a new regulator for $100.......and then it be just a bad connection.....$100 isn't all that much, but it sure would sucl to spend it...wait a few days for UPS....Then spend an hour R&Ring the regulator only to find the new one is slow as well..........
I had the same thing happen to me. My right window was really slow and the left was normal speed. I replaced the motor in the right door thinking I've solve the problem. NOT!
It turns out the guide track the window travels on and the ribbon track had a lot of old grease and dirt that cause the window to move slow. I cleaned it all up with degreaser and simple green. Put it all back together and problem solved. It turned out the orginal motor work just fine.
with this too. I guess it all boils down to taking the door panel off first to see what you have. I thought the scissor style didnt come in till 87-88 but J has enlightened me. Kinda makes me wonder if I got the first running change in my '85 with my two types of regulators. You still need to take the panel off to check the electrical connections and the items RSSSHEN has mentioned. Just let us know what you find and we will help you out with it.Good Luck!
