Where do I find replacement hoses?
Old Jun 25, 2010 | 09:08 PM
K.C.E.'s Avatar
K.C.E.
Default Where do I find replacement hoses?
I have a '94 LT 1 and am replacing the water pump and all hoses. GM no longer makes some of the hoses. Specifically heater hoses and the hoses that have a unique attachment to tubing (i.e. no hose clamp); therefore, the replacement part will be hose and tubing as a unit. Any suggestions?
And for the record......removing the knock sensor was a complete mess......I was very surprise how much fluid came out. In fact, more antifreeze came out of knock sensor hole than the radiator.....my bucket overflowed.
kc
Old Jun 25, 2010 | 09:15 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Just measure what you need and have the guy at the parts store cut it off the reel for you.
Old Jun 25, 2010 | 09:25 PM
c4cruiser's Avatar
c4cruiser
Try Rockauto.com for hoses. Or NAPA or CarQuest. While a dealer may not beable to come up with OEM hoses, you should be able to find every hose from aftermarket sources.
The knock sensors being at the bottom of the block hold back a lot of coolant. You got everything that was in the block from the water pump down.
Old Jun 25, 2010 | 10:02 PM
M. Schumacher's Avatar
M. Schumacher
Duck, the LT's have all molded hoses.
OP - Napa has them all.
Be careful of that little plastic restrictor in the one heater line. It breaks very easily.
Old Jun 26, 2010 | 08:16 AM
K.C.E.'s Avatar
K.C.E.
Thanks....
kc
Old Jun 26, 2010 | 10:49 AM
94z07fx3's Avatar
94z07fx3
If you want to bypass the TB, you can use generic heater hose like Duck mentioned and buy a one piece upper radiator hose for a '95 or '96. That will let you eleminate the T in the heater hose and its counterpart in the upper radiator hose.
Old Jun 26, 2010 | 11:36 AM
BADDUCK's Avatar
BADDUCK
Yep, cheaper and a straighter shot.
Old Jun 26, 2010 | 04:43 PM
chileverde's Avatar
chileverde
So for a 1 pc upper hose that rids yourself of the TB tee, what vehicle application would you use to purchase it? 1991 L98?
Old Jun 26, 2010 | 04:51 PM
BADDUCK's Avatar
BADDUCK
No, you would measure from the head fitting to the heater fitting at firewall, using the actual route for your car, and order by hose ID size. Just buy a good quality reinforced hose at the auto parts.
Old Jun 29, 2010 | 12:08 AM
chileverde's Avatar
chileverde
i was referring to the upper rad hose.
how about the 1996 LT4 - does it have the tb hose tee on the upper hose or is it one piece from the radiator to the motor?
Old Jun 29, 2010 | 12:10 AM
chileverde's Avatar
chileverde
if i read this right, the 96 corvette upper hose is the one i need...?
rob
Old Jun 29, 2010 | 12:47 AM
94z07fx3's Avatar
94z07fx3
rob
The 96 upper hose is indeed one piece. But I don't know if the part is compatible with the water pump for the L98. Take a look in C4 General at the CL never dissapoints thread and look at that 95 for sale craigslist ad. In that ad is a clear picture of the 95's upper hose and you should be able to tell from that.
Also, look at the passenger side of the heater hose routing. On the 94 there is a T that makes the connection to the passenger side of the TB coolant run. Removing that T and replacing that hose with generic makes for a clean TB bypass. If the L98's have a similar setup then you're golden.
Old Jun 29, 2010 | 12:51 PM
JM95's Avatar
JM95
O'Reilly Auto Parts has all water hoses manufactured by Gates. It took them 24 hours to get them at my store. Their web site for my 95 LT-1 basic listed all 7 hoses. If you need their part numbers PM me. Cost was about $135 plus tax.
Old Jun 29, 2010 | 11:17 PM
dolbnyc's Avatar
dolbnyc
I could not find the heater hose for my 92 except for thr U shaped hose. I got that on amazon it's a gates. The heater hose was like 1 inch on one end and 3/4 on the other.
I got 3 peices of straight hose 1inch and 3/4 and purchased a coupler reducer from Napa.
the other hose was 5/8. Get longer so you can route it before cutting this way it's not too short and you need to go back to the store
Old Jun 30, 2010 | 02:42 AM
chileverde's Avatar
chileverde
I'm not the L98 guy, I have a 94 LT1 like the original poster of this thread.
Old Jun 30, 2010 | 10:09 AM
dolbnyc's Avatar
dolbnyc
I got a samco set, try searhing for those too
Old Jun 30, 2010 | 12:55 PM
94z07fx3's Avatar
94z07fx3
Oh! Then yeah you could use the 95/96 one piece hose.
Sorry for the confusion I didn't understand what you wrote in post 8.
To Where do I find replacement hoses?
Old Jun 30, 2010 | 01:36 PM
MK 82's Avatar
MK 82
On my 96. I havent found anyone that repops the one that is mostly hard line. It goes to the overflow bottle, the steam tube, and the radiator. Anyone have a source?
Old Jun 30, 2010 | 01:40 PM
MK 82's Avatar
MK 82
Can you post the link to the U shaped one?
Old Jun 30, 2010 | 02:43 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
He's probably talking about the hose that goes from the (front of the) intake up to the throttle body. I don't think your car has that. It's 5/8" hose that forms a semi-circle on ~5" diameter.
