Distributor cap removal
Old Jun 25, 2010 | 11:06 PM
Dryoo7's Avatar
Dryoo7
Default Distributor cap removal
Now I'm feeling stupid. Washed the engine and now it will not start. Was going to remove the dist. cap and rotor and dry things out. But can't figure how to remove the cap. Any help?
1985 Vette, 4X3
Chuck
Old Jun 25, 2010 | 11:17 PM
Meds94's Avatar
Meds94
Cruising
1985 Vette, 4X3
Chuck
There should be 2 I think screws that are spring loaded on the cap push them down and turn to undo the cap.
Old Jun 25, 2010 | 11:44 PM
John A. Marker's Avatar
John A. Marker
Sorry, but the 85 has a screw down cap without and springs or "L" shaped swings arms....just four (4) screws.
Old Jun 25, 2010 | 11:57 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Yep...If it's like my 89, there are 4 screws around the base of the plastic cap. They are the same size as the hex in my electric screwdriver and those hex utility sets you can buy at the hardware store. (You know...with torx, allen, screwdriver bits, etc....)
Backout all 4 screws. There is a point where they'll release but stay in the cap. Don't try to removed them completely from the cap. Just make sure they're out of the metal base.
The cap fits VERY tight. You'll have to push the top of the cap sideways a bit to pop it off.
When you go to reinstall, notice the notch in the cap fits only one place in the base.
Do NOT loosen the bolt at the base or your timing will be changed. If you pull the plug wires, mark them so you remember which hole they go back in.
If there's a lot of miles on the car, replace the cap and rotor before installation.
Old Jun 26, 2010 | 05:15 AM
floridamale's Avatar
floridamale
good info
Old Jun 26, 2010 | 07:14 AM
c-4 lhozwalte's Avatar
c-4 lhozwalte
IIRC the bolts are 5.5mm.
Old Jun 26, 2010 | 08:48 AM
Pete K's Avatar
Pete K
Or 1/4 inch. Both fit.
Old Jun 26, 2010 | 04:22 PM
Dryoo7's Avatar
Dryoo7
Thanks for the help guys. The four are so small I couldn't see them in the afternoon light. What a tight fit.
Chuck
Old Jun 26, 2010 | 08:33 PM
JAKE's Avatar
JAKE
Be careful when replacing the cap because sometimes the wires can get caught under the cap and can be cut if not routed correctly through the little notch opening.
Jake
My son, Ryan M. Cameron, graduated from West Point on 22 May 2010! He was commissioned as a 2nd Lieutenant and I pinned on his first pair of "Butter Bars" PROUDEST DAY OF MY LIFE!!
Old Jun 27, 2010 | 08:53 PM
black88z51's Avatar
black88z51
Hey, this happened to my '84 when I was just rinsing out the engine with a little water. I didn't take anything appart, just let the car sit in the sun with the hood up for 2-3 days at least. It will dry out. Funny, last week I droped my cell phone in water and after letting the thing sit in rice (draws the moisture out) and sun for about a week the thing worked again. Good luck.
Old Jun 27, 2010 | 09:21 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
If you mix up the plug wires, it is possible to spend many fun hours trying to get them right. I know from personal experience
Old Jun 27, 2010 | 10:30 PM
black88z51's Avatar
black88z51
If you really must: There are 3 bolts holding the coil cap down - remove and pull the coil cap out, pull the wires out from the connectors. Then pull out all the spark plug wires (number them if you don't remember where they go back). Then you will turn 4 "J type hook screws" until the distributor cap pulls off. Then remove the bolts from the rotor and remove. Once you get all the parts out then I don't know what you have in mind to dry them out with. I know my pictures suck but these are all I have at the moment.
As the guys said above you should not be removing the entire distributor cap, to do this you would have to get into a very tight space at the bottom with a 5/8 wrench. The fear is that you won't know how to put it back and screw up the timing and would require another thread on how to do that.
Good luck.
Old Jun 28, 2010 | 08:27 PM
Dryoo7's Avatar
Dryoo7
Mine do not have J hooks. Those little 1/4" buggers. I have to use a magnetic 1\4" extention tool to re-set the screws. What a nightmare.
Chuck
To Distributor cap removal
