DeWitts Radiator Questions
Old Jun 27, 2010 | 01:20 AM
aklim's Avatar
aklim
Default DeWitts Radiator Questions
Are they having a sale? I almost pulled the trigger last year until something stupid happens in life. Anyone know when they might?
Are there directions from DeWitts itself? It isn't on the website
Can I the stock fans and if it isn't enough change to the Spal ones they have on the site or must it be done at the time of install?
What exactly is required if you use the Spal ones WRT the evaporator removal?
I believe with an auto I will be looking at the A90A. If we ever did the fan, we'd have to use the SP461, right? How difficult is it to move the evaporator canister?
TIA
Old Jun 29, 2010 | 03:26 PM
aklim's Avatar
aklim
bumping
Old Jun 29, 2010 | 03:29 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
My 86 was a drop-in.
No real need for special fans or the like.
Unless you have to have the trick stuff...
I trimmed the shroud around the drain **** for clearance and ease of access.
Old Jun 29, 2010 | 03:52 PM
slickfx3's Avatar
slickfx3
Default save you money, and spend it elsewhere I bought this and drop 30 degrees
a bargain with nice construction
http://cgi.ebay.com/ebaymotors/Alumi...Q5fAccessories
Old Jun 29, 2010 | 04:11 PM
aklim's Avatar
aklim
Originally Posted by slickfx3
Not sure it is that good for me. I have a 91.
Old Jun 29, 2010 | 04:36 PM
JrRifleCoach
Write them for a fitment to 91. The worst they can say is no...
Old Jun 29, 2010 | 05:03 PM
slickfx3's Avatar
slickfx3
check ebay dude
Old Jun 29, 2010 | 05:18 PM
aklim's Avatar
aklim
check ebay dude
I did. Just looking for a higher performance one than what I have.
Old Jun 29, 2010 | 05:22 PM
slickfx3's Avatar
slickfx3
sorry that don't make you year my fault, oh well Dewitts here it is.....
oh I just read your mods, sorry, you put out some HP as well, the radiator should take care of business
Old Jun 29, 2010 | 05:24 PM
aklim's Avatar
aklim
what do you have? whatever, I have 500 hp and build 700r4 putting out heat I live in Los Angeles, with AC on all the time....
Would be the same thing since it gets driven all the time in the summer. Thanks to the PO, I discovered why it was getting too hot. He had the fans tied together in some weird fashion and it fused one of the sets of wires. Have to get new connectors and relays to make it work.
Old Jun 29, 2010 | 05:25 PM
aklim's Avatar
aklim
I have an 383 making about 410 at the wheels.
Old Jun 29, 2010 | 05:34 PM
slickfx3's Avatar
slickfx3
nice power
Old Jun 29, 2010 | 05:45 PM
aklim's Avatar
aklim
nice power
Thanx. Could be better. All it takes is cubic dollars
To DeWitts Radiator Questions
