Where do I begin to look to fix this problem? it's a digital dash (not sure if all 86 vetts had this) but the speedometer works... the trip meter works... but the odometer appears to be stuck at 125xxx.4
the odometer is mechanical.
The odometer has an electrical feed to it. No cable
The mechanical odometer has a stepper motor that moves it forward one click at a time. I looked at the 86 manual and could not find the stepper motor signal in the electrical section, but I suspect it comes from the dash circuit and not the ECM.
If you have cut wires the FSM will help give the color codes to find out whats been destroyed. It can be complicated but just take your time and you will sort it out.
