K&N Air filter + MAF problems question
Old Jun 27, 2010 | 12:44 PM
MotorCity_87_C4's Avatar
MotorCity_87_C4
Default K&N Air filter + MAF problems question
Been chasing an intermittent code 34 on my 87 coupe. I have a K&N air filter. I replaced the MAF about 3 weeks ago and continued to have the intermittent code 34. Went back to the FSM and followed the troubleshooting procedure and it said the MAF was bad. I got an exchange on the MAF and got another rebuilt MAF. Could the K&N air filter cause a code 34 to return after less then 50 miles?
Old Jun 27, 2010 | 12:47 PM
floridamale's Avatar
floridamale
Did you over oil it ? also when you change the MAF you should do the relays also
Old Jun 27, 2010 | 01:13 PM
MotorCity_87_C4
Nope didnt over oil it and no didn't change out the MAF power relay.
Old Jun 27, 2010 | 01:27 PM
1stvet87's Avatar
1stvet87
Default code 34
I recently opened up my filter inlet on my 87 and got 33 & 34 codes repeatedly. Disconnecting the negative battery cable will clear the codes, but expect them to return for a period of time. The ECM has to relearn the new peramiters and adjust accordingly. It took a couple of tanks of gas before mine quit setting codes. I would probably go ahead and disconnect the battery and replace the MAF sensor relays, and then just drive and expect the check engine light for a while.
Old Jun 30, 2010 | 08:55 PM
MotorCity_87_C4
Still throwing the intermittent code 34. Changing the car's name from Nickel -n- Dime to Money Pit.
Old Jun 30, 2010 | 08:59 PM
WW7's Avatar
WW7
Here is what the book says could be wrong, theres more then the MAF that could be causing the code 34...WW
Code 34 (1985-1990) Clean the throttle body. Check MAF connections. Replace MAF relay. Replace MAF Sensor. Possible ECM failure.
Old Jun 30, 2010 | 09:08 PM
MotorCity_87_C4
ok, I have not cleaned the TB since last summer and have not replaced the MAF relay....yet.
Old Jul 1, 2010 | 01:49 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
I too have experienced the same problem.
IMHO;
Clear the codes and clean the MAF.
Ditch the K&N and replace with a paper unit.
It has been long recorded here that the early MAF and K&N's are not the best match.
Old Jul 1, 2010 | 03:07 AM
turbodiesel's Avatar
turbodiesel
its still ok to run the cut open lid with the factory paper filter? just a fram or wix?
Old Jul 1, 2010 | 04:45 PM
MotorCity_87_C4
Would just driving under 50 miles cause the new MAF to get gummed up and throw a code?
Old Jul 1, 2010 | 05:21 PM
vader86's Avatar
vader86
I ran the open lid with K&N before I got a SLP CAI, still runs a K&N. If the MAF is continually failing even with a new one, I would not suspect the filter to be the problem.
When I do clean and oil mine, I take it out and let it sit for a day on a towel so any excess will drip out. Sometimes I put it in front of an old fan. You only oil it til its just pink.
If the relays have not been changed, they should be. Its a good rule of thumb to always change the relays if you go to the expense of changing the MAF itself.
Assuming all that is good, I bet on wiring. ECM failure is rare.
Old Jul 1, 2010 | 09:49 PM
JrRifleCoach
Need to go thru the engine compartment and inspect all the wiring harness connectors for exposed copper. Chances are you will find some.
Old Jul 2, 2010 | 10:38 PM
MotorCity_87_C4
Changed the MAF power relay today. Looks like someone was messing with them an owner or two ago as they were not on their firewall brackets but laying down next to battery and on top of the main power connection terminal. The plastic that slides over the bracket was broken and the L bracket was bent and mangled. I need to get a new MAF burn-off relay now so I can attach it to it's bracket.
Old Jul 5, 2010 | 01:54 PM
MotorCity_87_C4
Update, 3 days no return of the SES code 34, looks like the MAF relay did the trick.
Old Jan 1, 2013 | 07:21 AM
Pingman326's Avatar
Pingman326
Thanks for posting the results !
To K&N Air filter + MAF problems question
