Gear Ratio help
Old Jun 28, 2010 | 03:52 PM
original84's Avatar
original84
Default Gear Ratio help
My 84 has the G92 performance axle ratio option on it. Does anyone know what the final drive ratio for this is? I have seen information listing the standard axle to be anywhere from 2.73 to 3.31 but I haven't been able to locate any info on this hi-perf axle ratio.
Thanks in advance!
Old Jun 28, 2010 | 04:12 PM
Sinistrad's Avatar
Sinistrad
Thanks in advance!
Accordding to this thread, there should be another code to tell you the gear ratio.
http://forums.corvetteforum.com/c4-t...iff-ratio.html
Old Jun 28, 2010 | 05:50 PM
vetteoz's Avatar
vetteoz
There is 2nd "G" RPO code that identifies the ratio
Only 410 cars are listed as having the G92 option in 84
Old Jun 30, 2010 | 10:37 AM
original84's Avatar
original84
Thank you!!! I have the GW4 RPO - 3.31
Old Jun 30, 2010 | 10:43 AM
original84's Avatar
original84
And I did see that when I was digging around. Just lucky - I didn't order it with that! Every now and then a blind squirrel finds a nut too!
To Gear Ratio help
