no Front Brakes
Old Jun 28, 2010 | 09:56 PM
85Corvettebob's Avatar
85Corvettebob
Cruising
Default no Front Brakes
Visit often, but never posted. I just painted all of my calipers, put in the rear brake spring and stainless steel brake lines and new fluid. I have pressure at the rear brakes but not the front. Any help would be great. This is an awesome web site and everyone is very helpful with providing great information. Thanks in advance
Old Jun 28, 2010 | 10:26 PM
MotorCity_87_C4's Avatar
MotorCity_87_C4
Did you bleed the front brakes?
Old Jun 28, 2010 | 10:52 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Bleed in this order:
passenger rear
driver rear
passenger front
driver front
Ensure you do not run out of fluid in the master. If you do, start all over.
Old Jun 28, 2010 | 11:00 PM
MK 82's Avatar
MK 82
Originally Posted by PLRX
That's cold man. No wonder the guy hasn't posted. He dreads some guy like you ridiculing him.
To the OP:
Either you installed the proportioning spring improperly or the front brakes have air. In the case of the latter, you would probably have spongy brakes.
Old Jun 29, 2010 | 11:33 AM
85Corvettebob
Cruising
I'm in the process of bleeding the fronts, and the back ones are done. The brake fluid came out of the backs with no delay, but there is no pressure on the fronts at all. I'm using the hand vacuum pump.
Old Jun 29, 2010 | 12:13 PM
jhammons01's Avatar
jhammons01
stupid question......are both the cups full of fluid? Check at the Master Cylinder
Old Jun 29, 2010 | 12:21 PM
85Corvettebob
Cruising
New Fluid in both cups.
Old Jun 29, 2010 | 12:24 PM
jhammons01's Avatar
jhammons01
OK......ask someone to pump the brakes for you, watch inside those cups for some sort of fluid movement....
I'm aiming at the possibility that something (crud or whatever) is blocking the front cup and not allowing fluid to drop down into the MC
Old Jun 29, 2010 | 12:31 PM
85Corvettebob
Cruising
Wouldn't that cause some suction in the hand vacuum pump at all? If I do press down on the brake they go right to the floor with no resistance.
Old Jun 29, 2010 | 01:19 PM
94z07fx3's Avatar
94z07fx3
I'd start with a bench bleed of the MC. You can do it on the car but need the bore of the MC to be level. If you put a small level on the MC lined up with the bore you will see how much you need to raise the rear to get it level and choose then to either do it in situ or on the bench. Install the MC bench bleeder lines and only when the air is out of the MC proceed to the lines and slaves.
Old Jun 29, 2010 | 01:35 PM
jhammons01's Avatar
jhammons01
The only other thing that would cause that would be that the MC o-ring collapsed for just the front.
I mean, it is odd that this happens at this time...but since the system is old etc. maybe it happened......
It's a simple mechanism....and only a few things could be wrong......if fluid is not pouring out somewhere...then the only other two options are "Blow By"
The only two places that "blow by" can occur are
A.) at the Master Cylinder
B.) at the brake caliper.
So, you have faulty calipers or faulty MC.
Old Jun 29, 2010 | 01:40 PM
jhammons01's Avatar
jhammons01
maybe you sucked something into the small hole while using that vacuum. It's just odd that the steps you've taken lead you to where you are now.....something strange occurred. I re-read your initial post trying to get a clue....
Old Jun 30, 2010 | 09:49 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
make sure that the bleeder holes are open on both fronts, and then see if gravity allows any bubbles or fluid at the calipers. if there are no bubbles or even a drip, there is a line blockage of some sort. Don't forget to close the bleeders.
I would also believe that you may have unknowingly let some bit of debris into the line, and blocked something.
What I would do, is have someone press on the pedals while you look into the master cups. both of them should get a pressure wave in the fluid when the pedal is pushed. I have noticed this when I have an assistant pressing the pedal for me.
On my 57 chevy pickup, the master is under the floor. I can actually press the pedal and look directly into the master cylinder reservoir and see the pressure wave as I move it.
This leads me to believe that all master cylinders experience this event.
try it on yours.
Old Jul 1, 2010 | 04:21 PM
85Corvettebob
Cruising
try it on yours.
Turns out the line at the master cylinder was not tight enough. Thanks to everyones reply. Duh on my part!
Old Jul 1, 2010 | 05:13 PM
jhammons01's Avatar
jhammons01
^^didn't you see fluid leaking out at that point??
Old Jul 1, 2010 | 05:29 PM
85Corvettebob
Cruising
When I was on the driver side with the vacuum pump I heard a sucking sound coming from the Master Cylinder. No fluid came out that way.
Thanks again for your help!
Old Jul 1, 2010 | 05:52 PM
jhammons01's Avatar
jhammons01
oh oh oh....that is right...you were using that pump.....
I see how that would make my initial thoughts incorrect. See, if you were using the friend method of "Pump, hold, release" you would have seen that fluid coming out.....
Glad you found it
To no Front Brakes
Old Jul 2, 2010 | 01:18 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Did you ensure the brake safety/shuttle valve is centered?
If not, the valve will shut off brake pressure to F/R depending upon the direction of the valve.
Old Jul 2, 2010 | 04:29 AM
rodj's Avatar
rodj
If you don't have friends , get Speed Bleeders
Old Jul 2, 2010 | 08:58 PM
JrRifleCoach
Will those fit blow-up dolls?
