insterment cluster issue
Essentially, if the light bulbs have a resistance value of 3, and the bad ground connection has a resistance value of 2, that is 5 ohms of resistance. That 2 ohms doesn't belong there. It should be 0.2 ohms at the most. So, amperage is mainly what will give you your brightness of the bulbs. So if you are getting 2.52 amps throughout the whole circuit, that would lower the brightness of you bulb, because if you do 12.6 volts / 3 ohms, you get 4.2 amps, which would be much brighter.
That was all an example. I tried to break it down for you to help you understand how a bad ground connection would cause something like this. That's where I would check first. Located the ground connection for the cluster, unplug the negative battery cable, measure the resistance value using an ohmmeter from the ground wire of the ground connection, to the actual metal surface that the connection is tethered to. It should be no more than 0.2 ohms. If it is more, you should clean up the connection with a wire brush or some sand paper. That will solve your problem.
The search function works very well on this forum. Use the one that's "for this forum" at the top right in both the "general" and "tech" OR use the "C4 Community 84-96" and it should do all of the C4 threads.
Example: http://forums.corvetteforum.com/sear...rchid=39400676
