I did this project on my 90... I wasn't too hard. You need to get the power seat rail, and a set of dual switches with the wiring harness. One complication I faced was getting the correct color of switch. It's been in place for several years and works well.
The plugs to the seat motors will be the same from '88-'96. Yes, the plugs to the seat motors on the ebay item will work but I can't say if the power plug would connect in the console. Does anyone know if the power plug in the console changed from '91 to '92? Maybe a search in some of the parts catalogs will give that answer if nobody knows.
As far as I know the electrical connections and switches are the same from 90-93. So this part should fit a 91. In 94 the switch arrangement changed for the passenger seat so 94-96 are different. There are differences in color for 90 through 93...90 is grey with orange lettering while later years changed to black with white lettering. As long as your car came with a power driver seat this a fairly easy and worthwhile upgrade.
Thanx.
Now how to fix the seat part? Just get the power rails and the rest should fall in place?
