Headlight Motor Question
Old Jun 29, 2010 | 03:31 PM
aklim's Avatar
aklim
Default Headlight Motor Question
2 headlight motors. One turns on when you flip the switch and stops quickly. The other seems to go on longer till it finally stops. This occurs on and off. What is the fix? Besides new motor, that is. TIA
Old Jun 29, 2010 | 03:33 PM
Cyclonite's Avatar
Cyclonite
When I replaced the "gel" bushings in mine they started going the same speed again. What yr is your C4? Early are different than later and this may not apply to yours.
Old Jun 29, 2010 | 03:43 PM
aklim's Avatar
aklim
Sorry, mine is a 91
Old Jun 30, 2010 | 05:30 PM
Cyclonite's Avatar
Cyclonite
Sorry, mine is a 91
So is the one I did this in. You can get replacement bushings at MA or Ecklers, etc, or I bought nylon bushings at a hardware store and then filed them down to the right thickness. IIRC they were 1/2" bushings, but do a search and some of the posts will tell which size is right.
To Headlight Motor Question
