fuel injector ???
Old Jun 29, 2010 | 05:37 PM
kito1989's Avatar
kito1989
Default fuel injector ???
can 1 bad fuel injector make one side of fuel rail not work, i ohm tested all 8 of my fuel injectors all but 1 came back with 16-17 ohm's. that bad 1 had 3 ohms.???
Old Jun 29, 2010 | 05:45 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
I have never had it happen, but my understanding is if you have a shorted injector that the ECM will shut down that bank of injectors.
Old Jun 29, 2010 | 05:57 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Indeed, if one injector is drawing more current than the ECM driver can produce it could cause all injectors on that bank to not perform.
Old Jun 29, 2010 | 10:57 PM
jfb's Avatar
jfb
You have a bad injector and it can make the injectors on that side not work. Try leaving the 3 ohm injector unplugged and see if it will start. You don't say what year vette you have, but early C4's had batch fire (all injectors fire at once).
Old Jun 30, 2010 | 06:42 AM
kito1989's Avatar
kito1989
thanks everyone, its a 1989. have a set of bosch III's on the way.
To fuel injector ???
