Courtesy lights staying on
I have replaced both door switches a few years ago with no issues everything has been fine since then. I checked both door switches today and they seem to work fine. The rear hatch switch works on both doors as well.
I'm wondering about the timer that delays the interior lights turning off ?
Any suggestions would be greatly appreciated.
Graham
I'm wondering about the timer that delays the interior lights turning off ? [1]
Any suggestions would be greatly appreciated. [2]
Graham
2. You are 100% sure that the dimmer switch is not at the top?
I'm thinking one of two things , door lock switch as lights are supposed to come on when the key is turned to unlock ??
OR
A relay that controls the auto off of the courtesy lights when car is started or locked up ??
There may be more but that the best I can think of , just not sure how to test those functions.
http://forums.corvetteforum.com/c4-g...nt-go-off.html
BTW the feature is called DAB "Delayed Accessory Bus" by GM and that may help your searches.
Drivers side door lock cylinder was not left completely upright when key was removed. !!
