reset idle after TB install
Old Jun 30, 2010 | 06:31 PM
tombrammer's Avatar
tombrammer
Default reset idle after TB install
Just installed a bored stock TB (52mm) on my 93 LT1 now can't get the motor to idle below 1000rpm? Checked volts at TPsensor is .5 like it's supposed to be. Unhooked battery for 30sec and then drove around town, still refuses to idle below 1000. Also pinched off all vacuum lines and that made no difference (to check for vacuum leak) any suggestions? Thanks
Old Jul 1, 2010 | 01:02 AM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
Did you clean (or replace) the IAC unit and reset it properly?
Old Jul 1, 2010 | 08:15 AM
tombrammer's Avatar
tombrammer
No I didn't, I just figured out from the FSM that the IAC and the TPS are different, I thought originally they were the same. Is the IAC the valve on the bottom of the TB, on the lower part that you can remove? I think now that is it. The FSM says; "Reset IAC valve pintle position; A. Depress accelerator pedal slightly. (does that mean with motor off or on?) B.Start (start motor?) and release accelerator pedal (do they mean "start" pressing the pedal and then release?), run engine for 5 seconds. C. Turn ignition "OFF" for ten seconds. D.Restart engine and check for proper idle operation?
Old Jul 1, 2010 | 09:56 AM
rodj's Avatar
rodj
http://www.corvetteactioncenter.com/...and+Idle+Speed
To reset idle after TB install
