Using datamaster???
Old Mar 22, 2002 | 04:23 PM
BAdAzZV8's Avatar
BAdAzZV8
Default Using datamaster???
Do I take readings at idle, WOT, cruising what? This is the first time I'm using the program, so I want to do it right.
I'm trying to diagnose my rich state, and I wanted to scan my ECM to see where my BLM's are b/c I guess this is what to look at for rich/lean conditions.
Old Mar 25, 2002 | 11:18 PM
BAdAzZV8's Avatar
BAdAzZV8
Default Re: Using datamaster??? (BAdAzZV8)
Come one guys, I know you guys know what to do.
Old Mar 26, 2002 | 12:41 PM
Warlock's Avatar
Warlock
You want to take you reading at all of the above and see how far your BLMs (long term fuel something in datamaster) are from 128 are under lots of conditions. Drive around a lot while logging data and look at the logs. Under WOT you want to check the voltage of your O2 sensor. It should be somewhere around .860 and fairly steady.
To Using datamaster???
