Power antenna question on '92
Old Jul 2, 2010 | 12:56 PM
mundo's Avatar
mundo
Default Power antenna question on '92
My power antenna doesn't re-track all the way. It goes up quite a bit but I don't think its going up all the way. Do they need lubricated? If so how?
Old Jul 2, 2010 | 01:01 PM
94z07fx3's Avatar
94z07fx3
If it is a lubrication problem it is also likely a dirt problem. Otherwise it is a broken ribbon problem. Use a PB Blaster on a paper towel to clean the antenna when it is up and then shield the car by making a little cup out of your paper towel at the joint of each segment and give it a squirt of the PB Blaster goodness. If this restores full movement then follow up with a white lithium grease in a few days. I think the PB Blaster is a great cleaner/penetrating oil but not a good lube.
