C4 Remote Door Lock Problem
Old Jul 2, 2010 | 03:43 PM
tednphx's Avatar
tednphx
Default C4 Remote Door Lock Problem
My 93 convertible door locks work fine using the switches inside on the doors. My FOBs will only unlock the passenger door and won't lock or unlock the driver's door. I've replaced the batteries in both FOBs and no change. Anyone have this problem? Any suggestions?
Old Jul 2, 2010 | 05:29 PM
Red Dwarf's Avatar
Red Dwarf
When the PKE system is inactive the FOB will only open the pass/door.
You turn the system "on", by holding the door button down until the locks cycle, you can check if it's "on" by inserting the key in the ignition to the "on" position & checking in the lower left corner of the info center for Passive Keyless entry. If you don't see the PKE lite up, recycle the door locks.
Turn the ignition to the "off" position, do not remove the key.
Then using the door button you can select which doors will unlock passively.
May take a little experimenting, but you'll get it.
Old Jul 2, 2010 | 05:36 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
And in just in case your not familiar with how the C4 FOB works, the door button on the FOB will NEVER lock or unlock the drivers door.
PKE = Passive Keyless Entry
Passive meaning that as you walk away from or up to the car, the doors will automatically lock or unlock as needed.
Old Jul 3, 2010 | 08:00 AM
markKlein's Avatar
markKlein
You expect the system to work like most remotes, it doesn't. Read your owners manual to understand how this system was designed to work.
To C4 Remote Door Lock Problem
