Just a quick question, is it possible to install the injectors on a 1984 crossfire 180 degrees off? I installed mine after having them serviced by FIC and now I'm wondering.
Al,
I haven't personally done injectors on an 84 yet, but I don't see how you could do that. They spray in a cone shape, and I'm betting they fall into a notch in the TB casting. If they're like other injectors (and I can't see why they wouldn't be), they don't care which way you connect the wires either as you're just applying power to a coil.
Al,
In short, no I don't think you can.
Marc
Thanks for the reply, after installing them I started wondering as I still have problems with the car not running.
Might end up pulling the throttle bodies and servicing them to see if that helps. So injectors will be coming out again anyway.
Again, Thanks. Al
Have you tried reading possible failure codes from the ECM?
No, that's something I haven't done. When/if I can get it to start the "service engine" light is not on.
Jon with FIC thinks I might have a problem with the TB's being gummed up.
Also need to check fuel pressure and whether the sock is plugged. Car won't run. Only way to get it to start is to squirt a little gas into the TB's then feather the throttle like mad. Stop and it kills, won't idle.
just a quick question, is it possible to install the injectors on a 1984 crossfire 180 degrees off? I installed mine after having them serviced by fic and now i'm wondering.
Thanks, al
al i marked them front and rear.. There is an alignment tab on the bottom of the injector that fits into the slot on the pod. No way to put them in 180 out. Regardless, they are a peak and hold coil, reversing polarity would have no effect. I still think you are not getting fuel into the injector pod, remove the regulators and boil ot the pods, then clean all ports using high pressure air and gumout. Do not mix up the regulator diaphragms, the front is different than the back so do one at a time. Also be real careful replacing the tiny torx screws that hold the regulator cap on. If they bind do not force them as they will snap off easily. Fit the screws by hand first and make sure you can run them in and out buy hand. Use a little anti seize lubricant when putting them back in. You will need a c-clamp to compress the spring down as doing it by hand is very hard to do and you will end up rupturing the diaphragm.otherwise its really an easy fix. Do the above only if you have fuel pressure going into the tb. If you have no fuel going in, then its fuel pump, relay etc.
Thanks for the information Jon, I'll get to it this week. After checking fuel pressure. Will post results.
Al
Thats where you should have started before assuming the injectors were bad.
Tom400Cfi pointed you in the right direction, first check fuel pressure and that WILL tell you the direction to go in.
Have good pressure 9-13 psi at idle and WOT, then you go in the direction of your TB's.
If not work backwards to the fuel pump. Fuel Filter... then the tank
Can't you just turn the key on and check the codes? Use a paper clip or one of those proper code readers and check the manual. Did the car run before you sent your injectors away?
When you turn the key on can you hear the fuel pump? So you are not getting any fuel? It might be as simple as your gas tank is empty, dump a couple of galons in the tank. The neighbors kid might of borrowed your fuel. Your gas gauge might be reading wrong.
Yes I can hear the fuel pump run when the key is turned on. I went to start the car a couple of weeks ago after setting for several years. One of the first thing I did was siphon out the old gas and put 5gals back with sea-foam.
Got the car to start, but would not idle and the only way to keep it running was to vigorously feather the throttle. Stop and it would kill. Now the only way to get it to start is to squirt a little gas in each throttle body. But then still have to continuously feather the throttle.
So had the injectors service, still same problem so new fuel filter. Still no improvement.
Going to pickup a pressure gauge and see what the pressure is. If that's okay then clean throttle bodies.
