I seem to remember the overdrive takes about almost 2 quarts, and you have to fill it to the plug hole anyway, so just have a little pan or rag ready, and be quick with the plug.
On the clear coat, you have to take the tire off the wheel and use high strength paint remover.
Be sure to check the wheels for cracks on the back side. It would be a shame to go through all that work, and then discover a crack just before putting the tires back on them
If you use low air pressure to blow out the lines to the radiator, you will need just over 2 quarts of Dexron III ATF for a refill. If you remove the fluid out of the lines, fill the OD then rotate a rear tire by hand for about 2 minutes, then top off the fluid level.
The filter is the same one used in a Ford FMX transmission filter that was found in early 70's Torino's, Cougars, a few Mustangs and some versions of F-150's.
CarQuest # 85926
NAPA ATP14717
FRAM FT1024
No need for a cork gasket; use a good RTV and apply a 3/16" bead around the pan rail and tighten all of the bolts equally.
Your wheels are wet painted.....You can sand and paint them...
Or if you want a polished look, take it to your nearest chrome plater and ask if they can give you the right finish...Not knowing where you live it is tough to make recommendations
Magmasters here in SoCal have a way to polish while the tire is still mounted.
Yeah, I think I will make a gasket as well. Never was a fan of using just silicone to "make" a gasket.
The wheels are the original C-4 Corvette wheels. I live in Mexico, so I am on my own for refinishing them. I would just like to get the paint off (remaining clearcoat), and maybe give them something of a "brushed" finish for now. Might polish them later...
Thanks,
vetterobert
Reason: correction
Normal paint stripper will remove the remaining clear coat without a problem. If the clear coat has peeled/chipped off some time ago you will see noticable discoloration between the recently stripped aluminum and the old bare aluminum.
(to the OP) Well, you are shooting yourself in the foot by using the gasket. If you follow the instructions for using just RTV for just a gasket, your end results will be more satisfactory.
The clear coat.....you can wet sand them until the slightly opaque clear coat is really thin...then respray clear back on top. Once you get to the Aluminum, you have to either polish or re-cut the surface. If you re-cut the surface on a lathe, you need an indexer and a template to cut your wheels....it's a huge process.
