New Cam Selection
Old Jul 5, 2010 | 11:52 AM
rssshen vette's Avatar
rssshen vette
Default New Cam Selection
Hey Guys I'm planning on doing a cam swap and wanted to get some of the knowledgeble forum members to give me some insight if this cam is a good match to my current set up.
My Set current set up:
383 Stroker all 4340 forged rotating assembly
58mm TB
TPIS Minin Ram intake
24lb Fuel injectors
Comp Cam 274* 220 int/ 224exh 475 lift
Dart Pro 1 Alum heads 180cc
1.5 int/ 1.6 exh RR
560" lift valve spring
Long tube headers
3000 stall convertor
3.73 rear gears
The cam I'm considerating considerating is
Part Number: 08-306-8 Grind Number: 290HR-12
RPM-Range: 2000- 6000
Valve Timing: 0.50 Duration: 290int /307exh
Lobe-Center Angle: 112 Duration @ .050" Lift: 230/ 244
Intake Centerline: 108 Valve Lift: 0.51int /0.54exh
Old Jul 5, 2010 | 01:17 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
I noticed you are going to use a Mini-Ram. Isn't the cam you listed more of a TPI type cam? Not to be negative but the Mini can spin you up pretty high given the chance. BTW looks like a nice motor.
Old Jul 5, 2010 | 01:43 PM
69SSC5's Avatar
69SSC5
what kind of power are you making/hoping to make out of your 383?
Old Jul 5, 2010 | 10:21 PM
rssshen vette
This cam was listed under the computer controlled and fuel inj cars for the model and year I would use. Iwant a cam that has good mid range and top end.
I haven't had the car on the dyno since I installed all the mods needed to compliment the stroker. It was dyno (279 RWHP) a few year back just after the stroker was installed. I'm looking to make at least 430 to the wheel. I'm guessing that I'm making around 390 at the wheel base on my track times. Low 7.80's @ 90 mph with 1.70 60ft in the 1/8 mile. I know there a lot more there. Between a cam up grade and a better tune I should in the 430+ range.
Old Jul 5, 2010 | 10:46 PM
rodj's Avatar
rodj
I noticed you are going to use a Mini-Ram. Isn't the cam you listed more of a TPI type cam? .
I would be looking for more lift
Comp 07-467-08 is popular with 383 owners ;same 2K -6K range
http://www.compcams.com/Cam_Specs/Ca...?csid=209&sb=0
Crane #119661
( one listed below is retro fit cam ; they do same specs in OE style roller cam)
http://cranecams.com/?show=browsePar...tNumber=119661
I have a GMPP 847 /Crane 109841 cam
( old design lobes compared to latest XFI cams ) in my 383 ( similar combo to your but with 195 heads)
410RWHP @6200
http://www.cranecams.com/index.php?s...41&lvl=2&prt=5
Old Jul 5, 2010 | 10:57 PM
vader86's Avatar
vader86
I think CC306 is fine and the 383 makes up for some of the choppyness of that cam, but I agree that a little more lift might perform better and not sacrifice anything. I would go with the one rodj recommended if you drive it often.
Shouldnt have any problem making your goal.
Old Jul 6, 2010 | 01:24 AM
tpi 421 vette's Avatar
tpi 421 vette
I have used all those cams, and they would all work well with a miniram. The 230/236 Comp will be the mildest one, but even the Crane 236/242 work real good on the street, and still has good street manners, but the idle is lopier... obviously!
Old Jul 6, 2010 | 02:02 AM
rodj's Avatar
rodj
Originally Posted by tpi 421 vette
even the Crane 236/242 work real good on the street, but the idle is lopier... obviously!
I love it
At least people know you have something under the hood.
Proper muscle car idle
Old Jul 6, 2010 | 02:37 AM
rssshen vette
Crane #119661
( one listed below is retro fit cam ; do same spec in OE style roller cam)
410RWHP @6200
Thanks guys for your input. Rodj the 07-467-08 has what I looking for. The car isn't a daily driver but I would like to keep some good street manners for weekend cruising.
Old Jul 6, 2010 | 04:48 AM
rodj's Avatar
rodj
I am impressed with how " docile " the 847 (234 /242 ) is.
Running a 750 HP DP carb ( for baseline tuning purposes ) it will come to a flat stable 700rpm idle in less than a minute ; doesn't pull down going into gear
Wicked response with a 3K convertor ( 3.73 ) but after I blew that one was running a 2200 convertor and no SOTP loss of bottom end or throttle response
Old Jul 6, 2010 | 12:44 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
You'll probably want more spring to go with that though.
Old Jul 6, 2010 | 07:19 PM
rssshen vette
I planned on getting a stronger set of springs. It's better to be safe than sorry.
Old Jul 8, 2010 | 04:55 AM
rssshen vette
Could you tell me if the Crane 236/242 created any issues with accessories and vaccum. I found a cam Comp Cam 08-468-8 I want to use but I'm a bit concern if this cam will create an issuse with the vaccum and accessories(i.e. A/C and power steering)
Old Jul 8, 2010 | 08:39 AM
rodj's Avatar
rodj
Never actually measured the vac on mine w/ 847 but using the original '87 booster felt no different stopping than past 10 years
Old Jul 8, 2010 | 09:14 AM
88BlackZ-51's Avatar
88BlackZ-51
Are you going to be upgrading the injectors? I would think at least 30's?
To New Cam Selection
