Valve noise on #8
Old Jul 6, 2010 | 11:20 AM
LBYRNES's Avatar
LBYRNES
Default Valve noise on #8
After rebuilding my '93 LT-1 I had a slight ticking from the # 8 lifter. I assumed (bad word) that I just had a little bit of adjusting to do on the rocker arm. Curiously the ticking would go away after the car warmed up.
The noise has gotten worse now that I have about 9,000 mile on it. The ticking is louder and there is a putt-putt sound coming from that side of the engine until it warms up.
Do I just have a valve adjustment issue, a collapsed lifter, or did I burn a valve. And yes, I know I should have fixed it sooner.
BTW, everything except the crank, rods and block were replaced during the rebuild.
Thanks,
Larry...
Old Jul 6, 2010 | 01:42 PM
JAKE's Avatar
JAKE
First thing is to pull that cover and have a look see. Guys have recently reported on other forums of noises like yours that turned out to be diaster caught JUST IN TIME.
If you don't SEE anything, then check the preload. If it's OKAY too, time to break out the tools. Valvetrain failures can be unforgiving -- Read that $$$
Hope this helps.
Jake
Old Jul 6, 2010 | 01:49 PM
LBYRNES's Avatar
LBYRNES
Hope this helps.
Jake
Thanks Jake. I just downloaded and printed your "sticky" off of the LS1LT1.com forum. I'll try that. Thanks for your help.
Larry...
Old Jul 6, 2010 | 03:55 PM
Churchkey's Avatar
Churchkey
Worn valve guides will sound exactly like a lifter going bad.
While you have the valve cover off rotate the engine to get both valves on the cylinder in question in a closed position.
Use a large screwdriver inside the valve cover gasket rail & apply/release pressure to the spring retainer. Watch for movement @ the valve stem.
To Valve noise on #8
