head light door problem on an 86
Old Jul 7, 2010 | 11:56 AM
tdr1919's Avatar
tdr1919
Default head light door problem on an 86
my 86 rightt side motor wouldnt close, I opened it up and repaired the loose magnets in the motor, everything else looked ok, i cleaned it up and greased the spring everything moved smoothly. when i turn on the lights it opens ok, but i hear a clicking sound from the
headlight motor. when i push in the switch in the door will not close on the first try, if i turn them on again & off then it will close, the motor sounds fine no binding, moves quickly, no delay.
any idea? relays? something with the motor? maybe that manual internal toggle switch.
Thanks,
Tom
