Jumping clutch safety switch
Old Jul 8, 2010 | 12:57 PM
Sea Fore's Avatar
Sea Fore
Navigator
Default Jumping clutch safety switch
I am new to the Vette-iverse and not the world's greatest mechanic so this may sound like a basic no-brainer question. When jumping the clutch safety switch, is a paper clip sufficient or is heavy wire required?
Old Jul 8, 2010 | 02:23 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
I wouldn't use a paper clip because it could short out against something. Why are you doing this anyway?
Old Jul 8, 2010 | 02:26 PM
Sea Fore's Avatar
Sea Fore
Navigator
Been reading all the threads about starting issues and wanted to rule it out.
Old Jul 8, 2010 | 02:57 PM
skybolt31's Avatar
skybolt31
My 86 had it jumped by cutting and stripping the two wires and joining them with a wirenut. One of those things that I was going to undo but never got to it.
I don't know that clutch switches are so troublesome that I would jump one as a preventative measure. In the event that it does fail, it is easy enough to troubleshoot, so I don't think you gain that much.
Old Jul 8, 2010 | 03:40 PM
Sea Fore's Avatar
Sea Fore
Navigator
Thanks, Sky. I am having the same issue that about 5,867 people have been having on here concerning my 1989 not starting consistently. Rather than start a new thread about the possible problems, I just wanted to know if a paper clip could carry enough volts to check it. When I tried it yesterday it would click but not completely engage. Usually if i turn the key enough times it will eventually engage. When it does, it turns right over and fires right up...the starter doesn't lag or anything.
Old Jul 8, 2010 | 05:21 PM
Bondami's Avatar
Bondami
From: Southside of Western Norte Americano State of Confusion, ColoFornia
St. Jude '13
Yes a paper clip is fine.. there is no real load on it.
I would use a small piece of insulated wire since its easier to get in the terminals.
Old Jul 8, 2010 | 05:41 PM
MK 82's Avatar
MK 82
Don't use a paper clip. Get a 2 inch length of stranded #12 gage wire. Strip back about a 1/4 to 1/2 inch on each end. Bend into a U and insert.
Less worry about shorts.
Old Jul 8, 2010 | 06:03 PM
0Paul Ruggeri
Former Vendor
That sounds like a bad starter.
Old Jul 8, 2010 | 06:22 PM
skybolt31's Avatar
skybolt31
As Paul Ruggeri said, that sounds more like a bad starter. I appreciate that you can easily rule that out if you jump the switch and still get the same problem, but why don't you just check for voltage at the starter. If you are getting voltage there when it does, it, you have just checked your entire starting system and know exactly where the problem is. Besides that if you jump the switch with something like a paper clip, you will then have to wonder if it is not starting because of whatever the problem is or if it is because your paperclip jumper is not making a good connection.......
Old Jul 8, 2010 | 09:35 PM
jfb's Avatar
jfb
DON'T use a paper clip. The starter solenoid draws large current, use insulated #12 wire and crimp some spade lugs on each end and plug them into the safety switch connector. A paper clip not only is too small, it is iron and will turn white hot and go up in flames.
Old Jul 8, 2010 | 09:58 PM
SJW's Avatar
SJW
You sure about this, my friend?
My 1996 FSM shows the wires to the clutch safety switch to be 0.5 square mm -- equivalent to 20AWG. No way that circuit's gonna carry enough current to need a 12AWG jumper. If it did, the clutch switch would have to be one heckuva beefy switch to handle the arcing from switching that much current. It's a relatively low-current circuit. I'd be surprised if it's more than an amp or two. It's used to switch current through the primary side of a relay on the '96 model year.
Even if it's in series with the solenoid on model year 1989, the solenoid's primary windings are WAY smaller than 12AWG.
That said, JFB's advice about how to construct the jumper is otherwise sound. Use the same size wire that's feeding the switch, and you'll be fine. I'd only use a paper clip as a one-shot attempt to get the car cranking in a desperation situation.
Live well,
SJW
Old Jul 8, 2010 | 11:52 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Yep, bad starter. Mine did the same thing.
I can't remember exactly for sure, but the solonoid (or spring) wears over time. It's fixable but delicate to accomplish. (There's a tech tip or internet site somewhere that explains the problem.) IIRC, we share starters from Toyotas of all things. They have the same problem.
If it were the clutch switch wiggling your left foot with the key turned all the way to start would be more likely to get it to start. By contrast, a bad starter (solonoid) acts exactly as you describe. (And, I don't believe it cares whether your car is hot or cold.)
To Jumping clutch safety switch
