Automatic Transmission Rebuilders
Old Jul 10, 2010 | 08:23 PM
LTxDave's Avatar
LTxDave
Default Automatic Transmission Rebuilders
Never built one myself, so I'm just wondering if this is something I can do in a weekend or if there will be machine work involved?
I'm considering getting a kit from pro-built automatics and either the dvd or rebuild manual. I've built several engines and following directions does not intimidate me.
Old Jul 10, 2010 | 08:43 PM
blown1981z28's Avatar
blown1981z28
It's not that hard of a job. You will need some special tools. A clutch tool to release the pressure plate in the drums and a bushing driver kit. Just make sure you lay it out as you take it apart and the cleaner the better. Watch cutting the lip seals in the drums. Always air check.
Old Jul 10, 2010 | 10:26 PM
Tom 35th anniversary's Avatar
I rebuilt mine from a pro-built kit myself. Everything needed was in the kit. When i was finished it actually worked great!!!! Get the video along with the tech manual, lots of good info. It really isnt that hard especially if your comfortable with engine rebuilds.
Old Jul 10, 2010 | 10:31 PM
samsonb's Avatar
samsonb
What kit number is it? Did yall also replace the torque converter?
Old Jul 10, 2010 | 10:50 PM
I believe it was the street and strip kit, 2600 stall.
Old Jul 10, 2010 | 11:25 PM
Marv02's Avatar
Marv02
I just ordered a Monster Mega Kit It was on sale for $499.00 Free shipping no tax.
This will be my first Trans rebuild aslo Take a look at U Tube Videos there free and give you a idea what we got our selfs in to.
The Trans kit I Ordered less the Heavy Duty 5 planatory gear set I wanted them but thats anouther $300.00 I not pushing that much popwer I had to have them.
I let you Know after I get back In the car if I did good or screwed it up. LOL.
Old Jul 11, 2010 | 03:10 AM
pablocruise's Avatar
pablocruise
You can do it.
A pair of snap ring pliers will be necessary for the front planet snap ring.
You can easily make the other essential tools so you don't have to spend big bucks on special tools.
You will need to grind a small notch into a long flat blade screwdriver.
This helps you with the center support snap ring.
You can easily make a spring compressor for the lo piston at the very bottom of the case.
Lip seals in the input drum pistons will be a challenge. However, you can also easily make a helper aid to slide them in without rolling them(bad!). -you will need an empty 3 liter plastic soda bottle-
With the same aid you use for those lip seals, you can use to size the input drum's shaft 3 oil seals.
Some trans-jel would be nice, but the tubs are really too big for one rebuild. You can use vaseline or other petroleum jelly just the same however.
Old Jul 11, 2010 | 03:29 AM
dogfish246's Avatar
dogfish246
I always wanted to learn how to rebuild a tranny! They always look so difficult with all the pressure plates, little metal ***** (look like bearings) and other stuff that seems difficult. I think it is more of knowing where each piece goes and you will be ok... Pete K is a pro, maybe he will add to the discussion
Old Jul 11, 2010 | 07:16 AM
M. Schumacher's Avatar
M. Schumacher
Rebuilding your first automatic over a weekend is not realistic if you want to do a careful, thorough job.
Get the DVD and watch it a couple of times before you start.
Old Jul 15, 2010 | 05:26 AM
PBA's Avatar
PBA
I have helped many people with there buildups on 700R4's and 4l60E's over the years. I will answer your questions no matter whose kit you are using. Let me know how I can be of help here? Dana
Old Jul 15, 2010 | 05:54 AM
Lemme's Avatar
Lemme
St. Jude Donor '10
What exactly does rebuilding the tranny mean and entail? I presume the box must be first removed from the vehicle. What is in the kit? Would the kit solve slipping issues?
Any explanation on how the 700r 4l60 works and what common failure modes to expect?
Old Jul 15, 2010 | 08:03 AM
Pete K's Avatar
Pete K
1) Depends on who you ask. In my view, rebuilding is the process of returning all wear parts to an oem new spec.
2) Yes.
3) Depends on the kit. A "kit is a bunch of parts tossed in a box, and there are different levels of kits. I have never once had a kit be all inclusive, and provide all parts needed for an overhaul, as every one wears differently. Rebuild Deluxe kits normally contain the typical wear parts only.
4) Too numerous to mention. Cause and effect. When 1 problem occurs, it usually wipes out everything. 3-4 clutch is the number 1 soft part failure in an old 700r4/4l60/4l60e. Number 1 hard part I normally see dogged out is a tie between the reaction shaft and the rear planet.
There is no short answer to your question about how a transmission works. They are very complicated. I know guys that have been rebuilding them for 20 years, that have no clue how they work, just what breaks, and how to fix it.
Old Jul 15, 2010 | 08:20 AM
Lemme's Avatar
Lemme
St. Jude Donor '10
Thanks. Very interesting devices thats for sure.
Old Jul 16, 2010 | 04:24 AM
Lemme's Avatar
Lemme
St. Jude Donor '10
Wikipedia gives a bit of an idea how it works and what it entails:
The 700r automatic gearbox consists of a torque convertor mated to a gear train. The engine connects to the torque convertor and the gear train connects to the drive shaft. The inherant stall speed is a function of the torque convertor.
The torque convertor consists of 3 elements: pump (connected to engine), stator and turbine (connected to gear train). The lockup clutch ties the pump and turbine together via the stator and hence eliminates slip once slip is less than 30%.
The gear train consists of a number of planetary gears with clutches. Gear changes are hydraulically operated via valves opened and closed by pressure switches.
Old Jul 16, 2010 | 05:06 AM
ndanl's Avatar
ndanl
I bought this book http://www.amazon.com/General-Motors...9270506&sr=8-5, gone through it a few times, got myself another used 700r4, made some practice on it, but I'm still not ready to rebuild mine
Old Jul 16, 2010 | 05:30 AM
Lemme's Avatar
Lemme
St. Jude Donor '10
My local car bookshop here in Perth wants three times the price as Amazon! Have ordered it from Amazon. Thanks.
Old Jul 20, 2010 | 07:59 AM
Lemme's Avatar
Lemme
St. Jude Donor '10
My tranny is now fixed and back in the car. This is the worksheet from the mechanic:
Work Performed
Remove /Replace Turbo 700
Flush trans lines & cooler
Straighten X frame (speed bump damage caused by lowering)
Parts
T700 Rebuild 4 speed Auto Trans - Extra components
Z pack clutchs, Brute sun gear shell, Heavy duty boost valve
Heavy duty servo, Drilled steel pistons, Stage 2 separator plate
Stage 2 shift kit , 2500 stall convertor ,12 Lts Dextron 3
To Automatic Transmission Rebuilders
Old Jul 22, 2010 | 11:56 AM
Lemme's Avatar
Lemme
St. Jude Donor '10
I thought the car was great after the intake / heads and exhaust work. Now with the hi stall and stage 2 shift kit things are starting to get racey.
The old slushomatic has got a new life. Now for the next mod ...
Old Jul 22, 2010 | 12:12 PM
Calderone's Avatar
Calderone
Cool,what you have ?
Old Jul 22, 2010 | 07:08 PM
Lemme's Avatar
Lemme
St. Jude Donor '10
