Intermittent no start issue.
Old Jul 23, 2010 | 04:01 PM
pearlvett's Avatar
pearlvett
Well it's not starting again. Checked with a timing light and it has NO spark while cranking. Anyone have any ideas?
Old Jul 23, 2010 | 04:04 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
When you have no spark, check power supply going into dist.
Old Jul 23, 2010 | 04:06 PM
pearlvett's Avatar
pearlvett
Thanks will do that next. If it doesn't start up when I try it out!
Old Jul 24, 2010 | 09:11 PM
pearlvett's Avatar
pearlvett
Ok ckecked power at the "BAT" connection both when cranking and not. I have power there. The question I have is on the 3 wire connector it has a "B+" and a red wire when should it be hot?
Old Jul 24, 2010 | 09:38 PM
CorvetteMike2024
Corvette Enthusiast
its been a while since I had my dist apart
Old Jul 24, 2010 | 09:40 PM
CorvetteMike2024
Corvette Enthusiast
Looks like B+ should be hot. It looks like its tied into batt.
Which one is the red wire?
Old Jul 24, 2010 | 09:59 PM
pearlvett's Avatar
pearlvett
"B+" is red on the 3 wire connector and the "BAT" wire is red
Old Jul 24, 2010 | 10:08 PM
CorvetteMike2024
Corvette Enthusiast
Im totally confused now. If this post sounds stupid, Im going to blame it on a senior moment.
What if you run a hot wire from batt to dist. Undo the factory batt wire in to dist and run hot lead there. ?
Been replying to to many threads
What about that coil test in the FSM pic?
Mike
Old Jul 24, 2010 | 10:14 PM
CorvetteMike2024
Corvette Enthusiast
Pic up coil test here? BTW... my shop manual is 89. If you want any other pages, I will look them up for you. Im out of idea's Mike
Old Jul 24, 2010 | 11:01 PM
pearlvett's Avatar
pearlvett
Mike
Not a stupid post at all. It's a post that goes right with how this car is making me feel. lol
I checked the wire from the batt to the "BAT" terminal and it checked OK. In the morning I will check the coil using the FSM pic IF it still doesn't start.
That has been part of the issue with trying to fix it is that it won't stay broke
Old Jul 26, 2010 | 09:36 PM
pearlvett's Avatar
pearlvett
Well I followed the diagram and did all of the test. Everything checks out. I had a couple of local guys say check the ingnition switch. What do you think? If that could be it how do you test it?
