E- Brake
Old Jul 11, 2010 | 04:33 PM
glassman74's Avatar
glassman74
Default E- Brake
Used it today, and now it will not release. How do you get it to release?
Thanks. glassman74
Old Jul 11, 2010 | 05:22 PM
sailorsteve's Avatar
sailorsteve
Thanks. glassman74
Could be jammed up in the lever assembly. Remove the seat cushion and then you can remove the cover. If you look at the pawl, etc, you will see how to release it with a screwdriver or other weapon. Be careful if it's under tension. If you don't use it much, it may need cleaning and a little grease when you get it released.
Old Jul 11, 2010 | 05:31 PM
glassman74's Avatar
glassman74
Thanks Sailor. That what is was. glassman74
To E- Brake
