a/c problems
Old Jul 11, 2010 | 11:04 PM
jettek91L98's Avatar
jettek91L98
Cruising
Default a/c problems
I'm having a problem with my 91 vette. the auto climate control panel keeps blowin the 5 amp fuse . so far I found the wires from the clutch melted so I re spliced it worked for a couple of minutes,then blew the fuse. also I know there is a bad relay under the dash that i have jumped out for the compressor to engage .I disconnected it the panel lit up and the heater worked ,fan blew then the fuse went again. any help would be appreciated,thanks
