New Fix it List - It never ends
Old Jul 13, 2010 | 11:28 AM
Aopsahl7's Avatar
Aopsahl7
Default New Fix it List - It never ends
I just dropped the car off at paint and will not get it back for a few days so now I am on a mission to get an agenda going for when it comes back. Here are the noticeable problems on my list.
1) When you first put the tranny into drive it clunks into it pretty hard. Even when your on the brakes it jumps forward when it drops in. Now I know every car will have a slight noticeable feeling when it gets into gear (my silverado has it) but this one is heavy. Like it kicks your head back. If I didn't know any better I would think i was revving it and dumping it into gear...obviously I am not. So that's first thing.
2) Front passenger side headlight gets stuck halfway through rotation about 25% of the time. Most times it just rotates through just fine, but on occasion it gets stuck and will fix itself if i open/close again.
3) AC Conversion? - There is no freon in the system now at all. How hard is the convert to 134a considering the fact that I cannot seem to find the R22 anywhere.
4) Wheel restoration? - I would assume that starting out with some 400 grit and working my way up to a 1200ish grit and finishing with some polish would work well. Any suggestions or thoughts?
I am suure there is more to come!
Old Jul 13, 2010 | 02:26 PM
walter schweigert's Avatar
walter schweigert
Regarding #2. If you have not already done so, do a search on the forum for a headlight repair thread. It involves taking out the headlight motor and installing three little plastic barrel shaped pieces. Yo may also have to replace the gear too. Takes about 2 hours to replace both sides.
Regarding #3 You will need to assess the condition of the compressor and the remaining system. Check for leaks, replace components if there has been a catastrophic failure of the compressor, etc. But, do not let anyone tell you that R-12 is not available. IT IS. Yours may already use 134-a since I do not recall the year of your vehicle. It would not use R-22.
Old Jul 13, 2010 | 03:47 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
#1 check your u-joints out and see if there's any play.
Old Jul 13, 2010 | 05:20 PM
Casket86's Avatar
Casket86
Regarding number 4, here is a link of how I did my restoration this spring, just as an example.
http://forums.corvetteforum.com/c4-g...light=polished
Old Jul 13, 2010 | 05:24 PM
StealthLT4's Avatar
StealthLT4
#2: This is probably just a weird problem only I had, but mine would only open half way, then twitch until I closed them again. Turns out one of the screws that secures the bucket to the bracket had backed itself out, and was hitting the hood when it tried to rotate. Probably not your problem, but its a good idea to go rotate it yourself by hand and see if anything is binding or in the way.
Old Jul 13, 2010 | 08:21 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Post up some pics when you get it back from the painter.
Old Jul 13, 2010 | 08:37 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Stuff like this is why its called a "Hobby"
Old Jul 13, 2010 | 08:57 PM
Aopsahl7's Avatar
Aopsahl7
Ha Ha I am not complaining I love it. I am just saying it never ends, but thats the fun part.
Aopsahl7's Avatar
Aopsahl7
Of Course.
Old Jul 13, 2010 | 08:58 PM
Aopsahl7's Avatar
Aopsahl7
Exactly what I was looking for. Thanks!
Aopsahl7's Avatar
Aopsahl7
Checked joints, no play. It just drops into drive like it wants to burn em up ha ha.
Old Jul 13, 2010 | 09:27 PM
Casket86's Avatar
Casket86
No problem. If you need anything, feel free to PM. I will be out until Sunday. We are leaving for the Black Hills Corvette Classic tomorrow morning.
Old Jul 14, 2010 | 12:53 AM
Mikes1991's Avatar
Mikes1991
Regarding freon R12 is what yourlooking for I suppose and from what I recall its all over ebay. As for the clunking yeah check universal joints but Id also check TV cable adjustment. If its pulled to tight I have found this to cause hard shifts tourq lockup issues etc
To New Fix it List - It never ends
