optispark drive mechanism
Old Jul 13, 2010 | 06:00 PM
choopes's Avatar
choopes
Default optispark drive mechanism
I noticed the keyed spline that drives the opti actually came out in my hand. It's about 2" long and connects to another spline up in the engine. This is the device that actually drives the opti. I'm curious about what's behind the cover, but not curious enough to remove it, if I don't have too. Can it be installed wrong? Is there another bearing or bushing in there that needs to be changed? Is there any way this could be the cause of the past 3 failures of optis?
Thanks!
Old Jul 13, 2010 | 06:02 PM
tblt44's Avatar
tblt44
Old Jul 13, 2010 | 07:36 PM
timmy 93's Avatar
timmy 93
Yes it drives the opti.Your cam shaft is what the spline goes into.It only fits one way.The 92-93 are different than 95-96 not sure which one 94 is.
Old Jul 13, 2010 | 09:40 PM
choopes's Avatar
choopes
I noticed a little play up and down back and forth. As a drive mechanism, it's tight. Are these changed with the opti? The only bearing then would be that on the front of the cam shaft. After 3 optis, call me a gambler. I'd like to try to get it right this time. My plan is a new Delco first gen. opti from Summit, modified with a MSD cap, rotor, and vacume and air inlet, and a new coil. If it don't last, hello Delteq!
Old Jul 13, 2010 | 10:15 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
good read on LT1's
http://www.enginebuildermag.com/Arti...t1_engine.aspx
http://www.corvettefever.com/howto/16758/index.html
Old Jul 13, 2010 | 11:49 PM
92WhiteVetteGuy's Avatar
92WhiteVetteGuy
Hi
Did you ever diagnose the cause of the 3 failures to your OptiSpark distributor?
92White VetteGuy
Old Jul 14, 2010 | 09:16 AM
choopes's Avatar
choopes
Code 36, The last time this happened I was in complete denial. Couldn't believe the opti could be bad. I had just changed it. It's off the car now. Waiting for money to buy a new one.
Old Jul 14, 2010 | 11:11 AM
timmy 93's Avatar
timmy 93
What kind are you buying.Is there no product support.
Old Jul 14, 2010 | 11:26 AM
choopes's Avatar
choopes
My plan is a new AC/Delco first gen. opti from Summit, modified with a MSD cap, rotor, and vacume and air inlet, and a new MSD blaster coil. If it don't last, hello Delteq!
Old Jul 14, 2010 | 12:56 PM
BrianCunningham
after 3 failures, I'd be checking the harness out.
To optispark drive mechanism
