Cheched vacuum today and ......
Old Mar 24, 2002 | 12:41 AM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Default Cheched vacuum today and ......
I'm pulling 20lbs after installing 1.6 ratio rockers, thats up from 16 before. These seems like alot. Do I need to adjust the timing? Also this is a MAP system from a 90.
Old Mar 24, 2002 | 05:56 AM
cohocarl's Avatar
cohocarl
Default Re: Cheched vacuum today and ...... (Budman78)
:confused: :confused: :confused: That does seem odd. I would think the vacuum would drop a little (at the same idle rpm) if you went to 1.6's due to the slight increase in overlap.
I've got 1.5's being pushed 218, .454, 110lsa, and I'm reading about 14 in. at 800rpm.
