Question on plug wires and....
Old Mar 24, 2002 | 12:59 AM
gears's Avatar
gears
Default Question on plug wires and....
I got some MSD plug wires from Summit.I noticed that they are all 90 degree boots,where as the vette has 2 straight boots.Is this ok or should I get some different ones.Secondly,my clutch and pressure plate are more worn than I thought they would be.Where is the best place to get those items,and the flywheel.Just as well do it all.Is the mid-america fidanza aluminum flywheel a duel mass?Any help would be much appreciated.
Old Mar 24, 2002 | 01:10 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Question on plug wires and.... (gears)
If you can route the wires to clear hot surfaces all 90deg boots will work fine. If not MSD has boots and terminals for sale so you can crimp on other boots if necessary.
Try Contemporary Corvette (link on my site) for the clutch, etc parts; they sell new as well as used parts and are pretty reliable.
