c4 7 speed, shifter locked in reverse when starting
Old Jul 14, 2010 | 08:31 PM
grayblack88's Avatar
grayblack88
6th Gear
Default c4 7 speed, shifter locked in reverse when starting
New experience, my 1988 C4 7 speed manual tran, when depressing clutch and starting car, shifter is locked in reverse and can not be moved to neutral. Normally car is parked in reverse, to start depress clutch, start car and move shifter into neutral. I can not move the shifter --the clutch pedal feels "soft" internal leak in the master cylinder?
I installed this clutch master cylinder myself five years ago. Possibly the slave cylinder? Any suggestions?
Old Jul 14, 2010 | 09:13 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Do you mean you can move the shifter into neutral, but not into gear? Does it shift normally with the engine off? If so you have a hydraulic problem. Generally I recommend replacing the master and slave cylinders at the same time.
Old Jul 14, 2010 | 09:30 PM
tblt44's Avatar
tblt44
7 speed ??? was that an option for 88 only???
Old Jul 14, 2010 | 09:37 PM
batchman's Avatar
batchman
My guess - steering column is bound up, wiggle the wheel. If the clutch was that bad the car would be trying to move when the engine started.
Good luck,
- Jeff
Old Jul 14, 2010 | 10:04 PM
Jbyrd43's Avatar
Jbyrd43
I think 7 speed is the 4+3
Old Jul 14, 2010 | 10:13 PM
tblt44's Avatar
tblt44
Ok how in the heck does the 4 + 3 work ?
Old Jul 14, 2010 | 11:33 PM
HlhnEast's Avatar
HlhnEast
Cool tranny. The OD part works in 2nd, 3rd, and 4th. I guess the idea was to save fuel around town but that where you have fun shifting thru the gears. It will downshift automatically when you get down on it just like an auto would, then back up when you ease back off it. I generally just leave it off until I get up to highway speed and then use it as a 5th gear.
Old Jul 14, 2010 | 11:38 PM
grayblack88
6th Gear
Default C4 this is 4 speed manual with 3 speed overdrive
Once started I can not move the shifter out of reverse. The clutch is depressed when I do this. It has a tendency to lurch back about a few inches. The car must be started with the clutch depressed and the car in reverse.
I am the original owner of this 1988 C4 and the car has only 52,000 miles with the original clutch.
Old Jul 15, 2010 | 05:53 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Your clutch isn't releasing fully. When you start it, its LIKE you don't have the pedal depressed all the way...even though you do. The torque load on the trans gears is what prevents you from getting it out of reverse. That the car will "lurch back a few inches" is due to the clutch dragging and trying to move the car.
Check your clutch fluid first, but at this age, I'm guessing that you have a bad master or slave cylinder. The master is easy to diagnose; if there is (brake) fluid on the inside of the fire wall, where the clutch pedal pushrod goes through, then your master is bad.
Old Jul 16, 2010 | 09:47 AM
grayblack88
6th Gear
Thanks Tom400, you are correct, I should have done this right away... I know better. The clutch master cylinder reservoir was empty... an external leak. I filled it, pumped the pedal to get pressure and was able to move shifter into neutral. Since I had previously driven the car about 50 miles and simple parked it in the garage, I didn't suspect a leak because the car and shifting had been perfect. thank goodness I made it home. I can replace the clutch master cylinder myself, so no problemo!
As for those interested in the 4 +3 manual tran, my daily driving in overdrive ( not city )gets around 18 to 20mpg and on the highway at steady speed around 23 to 24. In 2nd , 3rd or 4th overdrive, pressing hard on the gas will downshift. The overdrive is activated by a button on the shift ****.
To c4 7 speed, shifter locked in reverse when starting
