Fastener delimma (Did I forget something?)
Old Jul 15, 2010 | 08:27 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Default Fastener delimma (Did I forget something?)
Look at the pic below for reference...
After pulling my old motor and getting rid of it, I've installed a new one. I bought all new fasteners for the shortblock and heads. I reused most other fasteners except new ones for the accessory brackets. I dumped my AIR pump/bracket and installed an AIR delete kit.
These are the bolts I've have left over. Does it make sense I'd have these? Because the 8 bolts are 2", they seem too short for accessories brackets (since my replacement bolts were 2.25").
I installed 8 unique bolts in the DMF and the pressure plate. All of the bell-housing bolts are accounted for too -- including lower left stud/bolt.
I can't remember what these came out of but don't THINK I need them. This post is a last-ditch double-check in case someone else has an idea.
Oh yeah, transmission bolts are also accounted for.
Old Jul 15, 2010 | 08:39 PM
Tom 35th anniversary's Avatar
Damn!! i should know the answer to this. I have the same bolts in a pile on my bench. Cant for the life of me remember exactly what they go to till I put it back together!!!!
Old Jul 15, 2010 | 08:49 PM
Aardwolf's Avatar
Aardwolf
Looks like header bolts.
Old Jul 15, 2010 | 09:03 PM
JackDidley's Avatar
JackDidley
I was going to say intake bolts. Have to be one or the other. Exhaust bolts tend to be rusty though.
Old Jul 15, 2010 | 10:15 PM
WW7's Avatar
WW7
The 3 on top have the double nuts for the accesory brackets on the exhaust manifold (A/C, alternator and dipstick),,and some of the others are probably from the air pump bracket that you eliminated or are the rest of the exhaust bolts..WW
Old Jul 15, 2010 | 10:37 PM
GREGGPENN's Avatar
GREGGPENN
Duh,,,Exhaust manifold!!! Thanks!
Stock manifold bolts are 2". Beside the water pump, it's the only thing I really didn't address above.
I didn't think they were accessory related because those weren't black oxide.
Old Jul 15, 2010 | 11:18 PM
HlhnEast's Avatar
HlhnEast
Yeah thats what I figured too. After the new headers and header bolts these would be left over. Its a Chevy tho, it'll run with some missing
Old Jul 16, 2010 | 07:43 AM
78pacer's Avatar
78pacer
My guess is intake bolts....hence the rust on one. Like the OP said, double nutted for accessory brackets.
Mike
Old Jul 16, 2010 | 08:23 AM
LD85's Avatar
LD85
I was going to say alternator accessory bracket, & water pump have these types of bolts as well.
Old Jul 16, 2010 | 01:19 PM
GREGGPENN's Avatar
GREGGPENN
No more guesses are necessary. I determined they were exh manifold bolts.
To Fastener delimma (Did I forget something?)
