What I am looking for is a replacement blade for the fan motor I have. That's why I need the actual diameter of the blade itself, so it can be mounted on my stock shroud. I would imagine even with the Spal set up I would need it in the same size as I am currently using.
Would this be a true assumption?
Would this be a true assumption? Steve
Yes.
The "S" shaped blades are Quieter but, the Straight shaped blades actually pull more air in. Also, Use only Spal fans since they have a lot more torque than others.
