Wierd start when warm....
Old Mar 24, 2002 | 04:24 PM
flyinace2000's Avatar
flyinace2000
St. Jude Contributor
Default Wierd start when warm....
The caar will start 100% of the time when the car is cold, but if the car is already warmed up i will sometimes have to give it gas to prevent it from stalling.
Will
Old Mar 24, 2002 | 04:46 PM
bogus's Avatar
bogus
Default Re: Wierd start when warm.... (flyinace2000)
in the old days of carbs that would mean the choke was still open or something like that....
with the crossfires... gee... have you checked for codes? does that car have a throttle position sensor?
Old Mar 24, 2002 | 05:49 PM
MagRed_04's Avatar
MagRed_04
I had same problem with my '85 (TPI). Changed Fuel Pressure Regulator and injectors and it fixed the problem. However, not sure about a CrossFire. Have you checked fuel pressure at all?
JK
Old Mar 24, 2002 | 08:33 PM
JonM's Avatar
JonM
Have you checked your Thermac? There is a temperature sensor inside. On a cold engine the doors should move to close off air immediately. On a warm engine it should open.
To Wierd start when warm....
