Fuel Pump help **PLEASE**
Old Jul 18, 2010 | 09:02 PM
Yesterdayscorn's Avatar
Yesterdayscorn
7th Gear
Default Fuel Pump help **PLEASE**
About ready to pull the rest of my hair out....
OK, vette sat for about 8 month went to start and nothing, noticed the Fuel Pump did not come of for 2 sec when key was turned so took it out and replaced it and strainer and she fired right up.
Put it in the garage and the next day went to start and the same exact thing...no pump. I bypassed the fuel pump relay by applying voltage directly to terminal G of the ALCL and nothing so figured maybe I got a bad pump.....I removed it and put direct 12V and it did zilch.
Soooo...I go and get another pump....presto cranks right up. Later the same day go to start and nothing #$@%&.
I put a meter on the connection at the tank turned the key and get the 12V for about 2 sec, I then put voltage directly to the pin going to the fuel pump and nothing from the pump.
I find it hard to believe I got two bad pumps.....If the relay was shorting out could the blow the pump? I would think the fuse would go as well.
I'm so frustrated and at a loss and suggestions and help would be welcome.
Mike
Old Jul 19, 2010 | 10:42 AM
Yesterdayscorn
7th Gear
Free beer for any suggestions I bought the fuel pumps from Autozone (Airtech)
Old Jul 19, 2010 | 11:04 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Remove the pump and be sure you have power and ground at the pump. If so, take the pump back.
Old Jul 19, 2010 | 05:40 PM
mr.beachcomber's Avatar
mr.beachcomber
Default Could be the common ground on the tank!
Originally Posted by Yesterdayscorn
...I put a meter on the connection at the tank turned the key and get the 12V for about 2 sec, I then put voltage directly to the pin going to the fuel pump and nothing from the pump...
Having replaced my fair share of C4 fuel pumps, I've noted the following:
If the fuel pump relay is working correctly (~two second's worth of power to the fuel pump at startup), check the 12V positive output at the fuel pump connection.
If that's okay (meaning no loose or broken wiring connection from the relay to the pump), check your common ground on the fuel tank. It's exposed to the elements and tends to form insulating rust. If rusty, clean it up, make sure it's tight, and you should be good to go.
As far as fuel pumps go, it's unusual to have two go bad in a row; however, I prefer using high end products from Bosch, Delphi, or Denso. (Don't enjoy replacing parts within a year or so of installation!)
Good luck!
Old Jul 20, 2010 | 07:58 PM
rons85's Avatar
rons85
I agree - verify the Entire electrical circuit, including the ground path. In addition to the ground connection at the tank make sure that the Internal ground (and power) connections for the pump are good. Those spade connections can get loose and/or rust inside the tank.
the tip-off is usually signs of heat - showing on the wire insulation right at the crimp joint to the spare connector..
Can't hurt to also take a good look at the wire harness weathertite connector for the fuel pump and sender as well.
To Fuel Pump help **PLEASE**
