Depends on your motor. The 2 or 1 piece seal is at the rear I don't believe has an impact on your balancer.
Go with a 6.75" smaller external if your motor is externally balanced so you can clear the front cross member. If you are internally balanced, get an internally balanced one.
C4 of Year Winner (appearance mods) 2019
Aklim: I recommend the "Pro Race" brand, "Pro Stock" series though. Not too expensive but better than Pioneer Balancers that have had delamination issues.
For $10 more you can even buy one with a bolt-in weight (if you're unsure how the RA will balance). (Some light-weight ext-bal RAs can actually use a neutral balancer if the pistons are light enough.)
I remembered wrong. It was the "Pro Sport" model of the "Pro Race" brand. Item 34266 was the item I purchased. (As noted on their webside, ext balancers have a bolt-in weight. Another reason I liked this choice is because it is SFI rated -- which means it should hold up better (even for street driving).
Scat ext balance cranks need a 400 balancer. They don't have a "neutral" nose model (I don't think). I bought a Scat9000. They said it was supposed to be neutral nose. It was not. Read their website if you've got one of those.
Eagle has an ext rear / int front crank -- so it depends on what you bought.
I don't know about Lunati or other brands.
Stock config is ext rear/int front but you could have bought anything.
Originally Posted by rodj
It appears he may have a 2 pce crank in a one pce block
Sounds like a reasonable assumption...That would mean it should be int/int balance, right?
Just like my application, I couldn't be sure until it went for balancing. Because the Scat9000 series says it has a so-called lighter-[imbalanced] nose, I had trouble anticipating.
It turned out that heavy metal COULD have made mine internal balance on the nose if I wanted to add it.
