Mine just tipped over 88k and I did them just because they're 15 years old and have 88k on them. It was just recently so hard to tell if fuel economy has improved but it does run a tad smoother.
If you've got the money to do so, by all means. Its always better to do preventative maintenance in my opinion, especially with the age and mileage together.
I have a 92 LT1, how many O2 sensors are on there and any idea on the part numbers? I looked on the site listed and just wondering how much it will cost to change them all.
From: Portsmouth Virginia 396LT4 435RWHP/400RWTQ Best so far 11.26 @ 123mph
Being one of the cheapest cost items you can buy for a vette that can have a major effect on engine operation and performance,it just makes good sense to replace them as a maintenance item. 30 to 35 dollars a piece is peanuts. 95 has 3 sensors but only the 2 fwd. sensors are actually needed with the OBD1.
Rick
Yup. Cheap peace of mind on the preventive tip. If you accidentally break one of the pigtail connectors (they become brittle from engine and exhaust heat) you can buy them at NAPA Auto Parts stores.
Your '92 has two (one on each pre-cat). They can run anywhere from $15 each at AutoZone for the Bosch to upwards of $60 each for O.E.M. AC/Delco or Denso, depending on where you buy 'em.
