HELP! canton road race pan and engine install
Old Jul 23, 2010 | 01:47 AM
ekess744's Avatar
ekess744
Default HELP! canton road race pan and engine install
For those who own a canton road race pan, Can any of you provide some tips for installing an engine that has one?
We ground some off the motor mounts already but the pan is still hitting.
4+3 trans is still in the car.
Options I have come up with and dont like
1. dent the pan slightly
2. keep grinding and try to strengthen the mounts later
3. pull trans. (which I am not even sure would acomplish much)
Old Jul 23, 2010 | 02:31 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
People have to dent pans for strokers and other reasons. That's better than compromising your mounts.
If they're not already removed, take out the frame braces and see if that helps.
Call Canton and ask them WTF their expensive pan doesn't fit. Then get nicer and ask for tips!
-- or --
cut/weld to fix
Old Jul 23, 2010 | 07:30 AM
ekess744's Avatar
ekess744
-- or --
cut/weld to fix
I did a little reading on the subject and it appears that some fit and some dont... Mine clealy does not. It's so close to dropping in but so for away.
http://forums.corvetteforum.com/c4-t...g-oil-pan.html
Old Jul 23, 2010 | 07:38 AM
mseven's Avatar
mseven
People have to dent pans for strokers and other reasons. That's better than compromising your mounts. If they're not already removed, take out the frame braces and see if that helps.
never heard of anyone denting the outside...denting the inside to clear a crank etc. is a different story.
the frame braces has nothing to do with it fitting through the mounts.
Mine was close to the mounts but fit w/out grinding/denting or whatever (15-240T). Take a tape measure and do some measuring.
As to grinding the mounts that depends on how much and where on the mount.
Old Jul 23, 2010 | 07:51 AM
PDQUIK95's Avatar
PDQUIK95
From: Portsmouth Virginia 396LT4 435RWHP/400RWTQ Best so far 11.26 @ 123mph
Not sure of your Canton pan design for an 88 but the 15-240T pan clears on a 95 nicely with motor mounts and starter installed. Drops right into the crossmember motor mount stud holes behind an automatic easily.No denting or grinding required.
Rick
Old Jul 23, 2010 | 09:50 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
The only difference between your '88 and my '85 is that mine is an automatic. I installed my engine with the Canton pan in place and it went right in with plenty of room. Really have no idea why yours won't do the same. Do you have the clutch/pressureplate bolted to the flywheel? If so that is probably the problem, you have to clear the trans input past the pressure plate.
Old Jul 23, 2010 | 10:16 AM
Aardwolf's Avatar
Aardwolf
No trouble when dropping the engine in mine either.
Old Jul 23, 2010 | 11:52 AM
Steve85's Avatar
Steve85
Cruise-In V Veteran
I have done mine a couple times like this and I barrrrrely get the Canton pan through the motor mounts. I think I may have tweaked it just a smidgeon the first time I did it.
If I would just remove the tranny it would go in quite easily. Not sure why I don't because I also spend another hour aligning to try and get the input shaft in the bearing.
Old Jul 23, 2010 | 12:24 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
try installing the mounts on the engine before you drop it in
Old Jul 23, 2010 | 12:52 PM
Aardwolf's Avatar
Aardwolf
I had the mounts installed on the engine when mine fit.
Old Jul 23, 2010 | 02:17 PM
Steve85's Avatar
Steve85
Cruise-In V Veteran
Clarification..It's not the motor mounts that bolt to the engine that are the problem it's the frame supports for the motor mounts. The canton pan is like .000000001" too wide to go through
In order for the engine to not get hung up on the input shaft, it has to be far enough forward that it puts the pan right in vertical alignment with the engine stands/supports.
Last edited by Steve85; Jul 23, 2010 at 02:19 PM. Reason: horizontally challenged...wait, no, wrong word.
To HELP! canton road race pan and engine install
