Correct fuel pressure range?
Old Jul 23, 2010 | 05:13 PM
redjetty's Avatar
redjetty
Default Correct fuel pressure range?
I borrowed a fuel pressure gauge to check my fuel pressure in my 89 vette,,,, Haynes repair manual says the range is 34-39 psi while the manual that came with the car says for my make, model and year says 51-55 psi,,,, anyone know? thanks rj
Old Jul 23, 2010 | 05:59 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
It will run fine around 37-40. 51-55 is way too high.
Old Jul 23, 2010 | 08:49 PM
WW7's Avatar
WW7
Im having my car tuned right now and I was told with the vacuam line connected and the key on I should have 40 ft lbs of pressure.Once the car is started it should not drop below 40 ft lbs.....WW
Old Jul 23, 2010 | 10:14 PM
JackDidley's Avatar
JackDidley
Motor running around 43. Running with the vac line unhooked, around 5o.
To Correct fuel pressure range?
