Does my ABS require input from the speedometer?
Old Mar 25, 2002 | 11:26 AM
Red5's Avatar
Red5
Default Does my ABS require input from the speedometer?
I have switched from the 4plus3 to the BW t-56 6 speed. I dont have the speedo hooked up. The ABS says it has no signal. It does its self test at 4mph then works for a bit, then turns on the abs light and doesnt work.
When i hook the speedo up to the t56 an actual 5 mph reads 168 mph. Is there a way to fix this. Do I need it hooked up for my abs to work?
its an 86.
Old Mar 26, 2002 | 11:35 AM
Red5's Avatar
Red5
Default Re: Does my ABS require input from the speedometer? (Red5)
???????????????? :confused:
Old Mar 26, 2002 | 12:22 PM
-=Jeff=-'s Avatar
-=Jeff=-
yes the ABS requires the Speedo to operate correctly..
its an 86.
As for this above quote could you elaborate more.. I don't quite understand it
Old Mar 26, 2002 | 12:48 PM
Red5's Avatar
Red5
Default Re: Does my ABS require input from the speedometer? (-=Jeff=-)
Jeff,
I made the trans switch. My main question is:
Is the abs seperate from the speedometer?
I don't need a working speedometer, but I do need a working abs unit. I dont want to spend a lot of money getting the spedo to work only to find out that it still didnt help out my abs.
Old Mar 26, 2002 | 12:55 PM
-=Jeff=-'s Avatar
-=Jeff=-
Yes and No.. Yes it is seperate from the speedo, but no it gets the speedo info from the VSS like the speedo.
Once you get the Vss sorted out the ABS unit should work again.
Old Mar 26, 2002 | 04:40 PM
Red5's Avatar
Red5
UPDATE: Based off wiring diagrams and other information we have figured out the the ABS system on the 86 does NOT reference the speedometer. So now I get to figure out what wrong with the ABS. :rolleyes:
To Does my ABS require input from the speedometer?
