Injector soak?
Old Jul 25, 2010 | 01:05 PM
Bob2.0's Avatar
Bob2.0
Default Injector soak?
I changed my injectors a while back on my 94 coupe, and put on a set of MSD wires with E3 plugs. The car runs great. Love it. The miss is gone, and has lots of power. BUT, since changing all that stuff, it doesn't start with the first try anymore unless it is warmed up. Sometimes it takes three or four attempts now. Also the other day after it started, it started backfiring and acting goofy, lurching and stuff before it smoothed out and was fine again. I pulled two plugs, wondering if one of my injectors wasn't leaking, but didn't smell or see gas. Before I pull the other plugs, do any of you have an idea what could cause this?
Old Jul 25, 2010 | 01:27 PM
STL94LT1's Avatar
STL94LT1
Fuel pump, fuel pressure regulator?
Old Jul 25, 2010 | 07:00 PM
Bob2.0's Avatar
Bob2.0
It just seems terribly coincidental to me that the problem would happen right after the injector change. I'm wondering if one of them is leaking fuel into the cylinder, causing a little flood condition that needs to get cleared.
Old Jul 25, 2010 | 08:20 PM
surfer93's Avatar
surfer93
Pull the injectors out, leave on the fuel rails and put paper towels under the injectors. Turn on the ignition and turn off, look for wet spots, I have seen more than one new injector leak.
Old Jul 25, 2010 | 08:55 PM
69SSC5's Avatar
69SSC5
first thing i would do is check the fuel pressure,,,
Old Jul 26, 2010 | 05:31 AM
toptechx6's Avatar
toptechx6
Can't do that with Bosch III's because there are no retaining clips. Install a fuel pressure gauge, pressurize the rail then pinch off the return line to the tank near the fill neck to see how quickly you lose pressure.
I had a similar problem after installing Bosch II's, Jon exchanged them for a set of III's calibrated specifically for 93 cars, they cured my long crank time.
Give him a call after doing the above test to see if he has a suggestion.
Old Jul 26, 2010 | 09:49 AM
Bob2.0's Avatar
Bob2.0
Hi Toptechx6, I was hoping that you'd chime in. I've never done the fuel pressure guage thing, so I'll look around for a thread that explains it. Your advice is always good. When you come to the next Forum, I'll owe you a steak dinner.
Speaking of steaks, yesterday was the worst ever. I took my son out to lunch and when I got back in the car to leave it took awhile to start. When it did finally get going it ran very rough, and stalled a number of times as I sat there in the parking spot. I kept at it and eventually it smoothed out and ran like normal. I put it in gear, took off and it accellerated great, idled great and gave me no problems. I'm just picturing a cylinder filling up with gas while it is parked...
Thanks again for your help.
B2
Old Jul 26, 2010 | 10:01 PM
surfer93's Avatar
surfer93
Vary easy to do, on the pass. side fuel rail, you will see a shrader valve pointing down, take off the 2 vacuum lines and unscrew the cap on the valve, then put your fuel pressure guage on and turn the ignition ON.
You need to pinch off the return valve by the gas cap. It is the hose on the bottom and comes in from the right. Use vise grips to pinch off(be vary careful not to pinch to hard and break the hose).
Old Jul 27, 2010 | 03:43 AM
toptechx6's Avatar
toptechx6
B2
Your imagination may not be that far off the mark. A word of caution; a leaking injector can indeed fill the cylinder with fuel and if that happens it is possible to damage the engine when restarting due to hydro-lock.
One test you can do without a pressure gauge would be to remove the dipstick and smell the oil, if you do have a leaking injector the oil may be contaminated by the excess fuel that gets by the rings. Not very scientific of course but if it does smell like gas you are probably on the right track.
As good as Jons product and service I'm sure he would admit that an occasional bad injector gets through, again I will suggest calling him to consult, he may have some suggestions, good luck.
Old Jul 27, 2010 | 06:03 AM
mtwoolford's Avatar
mtwoolford
a leaking fuel injector can do more than fill a cylinder; in my own experience, over the course of letting the car sit for one week, the pan and crankcase were filled COMPLETELY with gasoline; all this from one injector that went drip, drip, drip.
Old Jul 27, 2010 | 06:43 AM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
One test you can do without a pressure gauge would be to remove the dipstick and smell the oil, if you do have a leaking injector the fuel may be contaminated by the excess fuel that gets by the rings. Not very scientific of course but if it does smell like gas you are probably on the right track.
your car should run right, and injectors can leak, you have an LT1, its a 20 minute job to install new ones, Call me today and I will send you out a new set under our 3 yr warranty. Send the old set back after you get the new ones in. This way the car won't be down
Jon
Old Jul 27, 2010 | 10:58 PM
jfb's Avatar
jfb
Black exhaust when it starts and runs rough, is a sign of too rich fuel caused by leaky injector/s. Fuel pressure should be 35-42 psi and hold up for at least 30 minutes with the ign off.
To Injector soak?
