Oil Sending Unit
Old Jul 26, 2010 | 08:00 AM
twotone84vette's Avatar
twotone84vette
Default Oil Sending Unit
Hello All,
Does anyone know where the oil sending unit is located on '84? Are they prone to leaking and easy to replace?
Old Jul 26, 2010 | 08:11 AM
rodj's Avatar
rodj
Usual position is in block behind dist and yes they commonly leak with age
Old Jul 26, 2010 | 08:30 AM
WW7's Avatar
WW7
But unless you know for sure its the sending unit do a little more checking.. It could also be the rear of the intake at the China wall or the distributor oil gasket..WW
Old Jul 26, 2010 | 08:59 AM
LD85's Avatar
LD85
temp is above the oil filter, pressure is on the china wall in the back
Oil Sender
Oil Pressure
Oil Temp
Old Jul 26, 2010 | 09:32 AM
twotone84vette
Thanks for the info and the pics.
I was able to locate the oil pressure unit and it looks like the middle pic. It's the original unit on an '84 with 44K on the clock.
Where is the oil sender unit located?
I'm getting decent dripping with the engine running coming from the top back of the block. I will check the sources you mentioned.
Old Jul 26, 2010 | 09:45 AM
Muffin's Avatar
Muffin
Unless the 84 is different than the 85 the sender should be beside the pressure sensor.
Old Jul 26, 2010 | 09:53 AM
JackDidley's Avatar
JackDidley
When they leak, they leak big and bad since they are under pressure.
Old Jul 26, 2010 | 06:57 PM
vetteoz's Avatar
vetteoz
Old Jul 28, 2010 | 08:25 AM
twotone84vette
Without removing wiper motor, I was able to see oil on the oil pressure switch. Once I get in there and get a better vantage point, can I determine that the switch is not getting soaked by way of a leaky intake?
Thanks again
Old Jul 29, 2010 | 11:46 AM
twotone84vette
Removed wiper motor to get at it and sure enough, the sender was soaked and leaking.
Used a plumber's basin wrench to get it out
Thanks for the help!!!!
To Oil Sending Unit
