Head porting article.
Old Mar 25, 2002 | 01:16 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Head porting article.
FYI: the May, 2002 issue of CHP has a nice article on head porting by a novice with expert guidance.
It may have some tips/encouragement for those who are thinking about it but not done one yet.
Old Mar 25, 2002 | 01:26 PM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Default Re: Head porting article. (65Z01)
That article is :cool:
The camshaft stories were very interesting. :yesnod:
Old Mar 25, 2002 | 07:16 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
I have the article and its pretty good.
I pulled my LT4 heads and started to port them myself but quickly concluded that it was worth the money to have someone who know what they are doing.
You should have an expert do the 3-angle valve job and it turned out not to be that much more for a shop to do the whole thing. You may want to call around your area.
Old Mar 25, 2002 | 07:31 PM
65Z01's Avatar
65Z01
Default Re: Head porting article. (Mez)
Maybe a CNC shop would be more reasonable than in the article. Of course I would want em flow benched after I ported them to assure all flowed in the ball park. Plus I would just like to do that job; it sounds like fun and very rewarding (I like doing my own work where possible). But I will check out pricing when it's time.
Old Mar 25, 2002 | 08:44 PM
Mez's Avatar
Mez
Check out my web site
http://temp.corvetteforum.net/c4/tmezger/
for the story regarding my head porting experience. I am extremely happy with my choice.
Old Mar 25, 2002 | 09:12 PM
65Z01's Avatar
65Z01
Nice set of pics on the porting job.
BTW, what was the A/F ratio at WOT on those dyno pulls? Looks like it started out at 14.7:1 and dropped into the low 12s.
Old Mar 25, 2002 | 09:14 PM
Dan Parker '96's Avatar
Dan Parker '96
Does go to show ya...all things being equal... concentrate on that exhaust side and equalize the intake/exhaust ratio... :)
Old Mar 25, 2002 | 09:22 PM
Corvette0096's Avatar
Corvette0096
Default Re: Head porting article. (Dan Parker '96)
Chp=? :confused:
Old Mar 25, 2002 | 09:24 PM
65Z01's Avatar
65Z01
Default Re: Head porting article. (corvette0096)
"Chevy High-Performance" magazine.
Old Mar 31, 2002 | 09:42 AM
Rich B.'s Avatar
Rich B.
I ran out and got the CHP mag. It's quite good.
If you want more diagrams, cutaways showing metal to be removed...
...Or need GM part #s for older HP parts; get a copy of "How To Hotrod Small-Block Chevys" by Fisher & Waar; HP books, 1976.
It's out of print, but Amazon has them in the Used section...
I've had a copy of this book since the late '70's; loaned it out, never got it back...Ordered a "used" one from Amazon last Sept; it came in in "brand-new" (unopened!) condition, at half-price...(~$9.00)...Soft-cover...
It's old; but the head (and all the articles) specs still apply...
Old Apr 1, 2002 | 05:13 PM
Mez's Avatar
Mez
The AFR on my dyno runs were better after porting. It takes a second or two after WOT for the AFR to change at the meter.
The were low 12.3 - 12.5 before and 12.6 - 12.8 after. The Dyno shop said you want it to be about 12.6-12.8 for max power. By the way, the computer has not been reprogramed and has the stock exhaust system.
This car runs very smooth and hard from the stock 725 rpm idle right up up to 6400 rpm fuel shut off. I highly recommend having having your heads ported if you want to keep the stock cam and stock exhaust.
To Head porting article.
