ECM programming: GMRPO, Tuner cats.......info
Are there any programs out there that allow you to program higher? What does tuner cats go to?...
Anyone else have a problem with higher reving motors? Trying to stay away from aftermarket ECU setups.
Let me know what everyone thinks.....all advice helpful.
Tom
The stock GM 730/727 $8D code only goes as far as 5600/6200-ish RPM, if that's the one you're asking about. There is nothing to program beyond that point unless you either write new code or change to another ECM. You might take a look at the 749 code - I don't know what that uses for an upper RPM limit, it might be different.
IMHO accurate spark programming at 7500+ mandates a conversion to some kind of DIS also - I don't think the HEI system has sufficient inherent resolution to make timing programming meaningful at that RPM, at least with the 730. I think it's a dwell/coil saturation limitation with the GM ESC module, but I haven't come up with a way to verify that experimentally so I'm only hypethesizing at this point from what I see on my tests. If you run across any data I'd be interested in seeing it.
DrJ
The 93 Y-body ECM's have variables to 7500. Fuel maps,PE, and timing.
Not shure how bad the conversion would be. Some sort of opti spark setup would be needed along with dual O2 sensors.
I would have to get a full schemematic and compare.
Dennis
you may be pushing your luck a bit with the factory ECM although it of course can be made to work.
tell us about that engine!!! sounds like a screamer. I take my ZR1 that high, but that engine loves to rev.
I know fo a few guys running mid7000 RPM setup with the factory ecm's. Phil(LT401) is one of them. He shifts his motor at 7300+.
Tom I have a set of schemes. I am comparing the 93 to the 7730.
I will keep you posted.
Dennis
