What times should i expect with the new 3.54s
With the mods i have and the gears iam getting what 0-60 and 1/4 times should i expect.
[Modified by CORVETTE MIKE, 11:56 AM 3/25/2002]
1 Post
Cruise-In III Veteran
Re: What times should i expect with the new 3.54s (CORVETTE MIKE)
Thats really hard to guess Mike... depends mostly on the driver, track conditions and weather.... best way to find out is just go to the track and find out.
Re: What times should i expect with the new 3.54s (Springer's 95)
Personally, I would have went with a set of 3.75 gears, you'd be much happier with those in the LT1 motor.
Just my $0.02
Just my $0.02
Received 1,401 Likes
i'll guess somewhere in the mid 13's, on the high side maybe
[Modified by vader86, 6:35 PM 3/25/2002]
I believe that nickd posted a 1/2 second increase on his. I never ran mine with the 2.59 in it before going to the track. I have a friend that has a 94 A4 with 3.07 gears and he was running 13.80s. My best is 13.49 and consistantly 13.50s. Also keep in mind mine is a vert. We both are running street tires, were running at the same tracks on the same days, and have little track experience. I dont want to start any flames here but I wonder how many of these people who tell you to go 3.73 instead of 3.54 have ever had both gears with a A4. I can tell you that I went with the 3.54 because the price of a rebuilt unit was much cheaper then I could find a 3.73. I paid $759.00 exchange at Zip on a group purchase, and because I live about 90 miles away I was able to drive there and save the shipping. When I purchased mine I ask Justin why zip only is doing the 3.54 and not the 3.73 and he explained it to me as being the 3.54 will hold up better. Im not going to try and explain this, if you have questions about it call him. Justin is a very good at differentials and he would be glad to explain the differences. I origionally wanted the 3.73 but I was looking at about $500.00 more for the rebuilt diff. For a 5% gear change I couldnt justify that much money. One other point I would like to make is if you read any of the testing that TPIS did with the 92 LT1 vette that they used as a test car, they installed 3.54 gears in it as well. Sorry about ranting on about this but if you do change gears Ill bet it will be the best seat of the pants improvement you will ever do for the money. Good luck!!
Re: What times should i expect with the new 3.54s (Red 86 4+3)
I went from 2.59's to 3.54's in my 94 convertible. My best with the 2.59 was a 13.82@101mph,
since the gear went in I have run consistent 13.30's@104.5-105.5mph.
I have run new bests of 13.25 @ 105.9mph and 13.23@105.5mph.
Did the rearend you purchased from Zip come with the side yolks? Did you also purchase the heavy duty rearend cover for $325.00?
Re: What times should i expect with the new 3.54s (Seattle 6spd)
Newbie question... What's the stock rearend on a '93 6spd???
Is it a 2.59??? :U
Is it a 2.59??? :U
if you have RPO G92, what is your other Gxx code. I'll bet that G92 for a M6 is 3.45
Re: What times should i expect with the new 3.54s (mfranco)
About when did you purchase your rearend? The reason I ask is because when I spoke with Justin yesterday he told me that they come with the side yolks but I thought the price was awfully cheap to include the side yolks.
Hi Mike,
Here are numbers you requested:
0-60mph 60-100mph 0-100mph
Stock 94 6 speed 5.3 sec 6.7 sec 11.8 sec (24 cars tested)
" " Auto 5.6 sec 6.9 sec 12.4 sec (16 cars tested)
Similar 94 Auto* 5.0-5.3 sec 6.5-6.7 sec 11.3-11.7 sec ( 2 cars )
* With only two cars tested that were setup like your is now, your time to speed should range in the group listed here. We believe that more cars need to be tested to get a really fair estimates. Sorry, we do not do quarter mile testing.
Hope this will be of help.
Stan :chevy
Stan :chevy
Re: What times should i expect with the new 3.54s (cprgmr)
I'm throwing in 3.54s and a 2800 stall Vig next month and I'm hoping for low 13's... Dare I say high 12's??? :D
Is it a 2.59??? :U
Is it a 2.59??? :U
[Modified by jay17, 7:37 PM 3/26/2002]
